The BritishV8 Pub
tr6turbo
Dale Knapke
Sidney, Ohio
(169 posts)
08/24/2008 09:44PM
1972 Triumph TR6 Ford 2300, 4 Cyl Turbo
TR6 Turbo Engine Carnage Pictures
Posted by: tr6turbo
Date: June 14, 2009 09:00PM
I had a number of requests to post pictures of the destruction when I got back. Here they are.
Things could have been worse. The head is OK except for slightly bent valves and I think I can save the piston.
mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
1974.5 MGB/GT 3.9l Rover
Re: TR6 Turbo Engine Carnage Pictures
Posted by: mowog1
Date: June 14, 2009 10:21PM
Yep.
You lightened that block somewhat!
RMO 699F
Mike Maloney
SW Ohio
(531 posts)
12/09/2007 12:28PM
Posted by: RMO 699F
Date: June 14, 2009 11:13PM
Dale, glad you could save the head...I know that was a huge concern for you....
kstevusa
kelly stevenson
Southern Middle Tennessee
(985 posts)
10/25/2007 09:37AM
Posted by: kstevusa
Date: June 15, 2009 07:32AM
Dale, at least the valve did not break!. Could have taken out the head. Enjoyed seeing you again. Man you di a JAM-UP Job. that's a good sized hole for just a 4 cyl.
mgbreis
Ryan Reis
Beatrice, NE
(203 posts)
07/16/2008 11:07AM
Posted by: mgbreis
Date: June 15, 2009 09:58AM
Dale, for those of us that weren't there, what happened? Too much boost? I really like your conversion, you did a nice job. I've always thought that the boosted 2.3 is a neat motor.
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1151 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: June 15, 2009 11:22AM
WOW!
Not what I like to see, but I guess it can happen. I hope you had fun before this block blow!
Back to the drawing board and maybe use uprated internals so this won't haunt you again.
Date: June 15, 2009 11:35AM
That could all be welded..... ;-) ;-)
Date: June 15, 2009 03:07PM
Hi Dale, as bad as it looks, you probably had a "whew" moment when you pulled the head -- assuming no pics of it means it came through unscathed.
tr6turbo
Dale Knapke
Sidney, Ohio
(169 posts)
08/24/2008 09:44PM
Posted by: tr6turbo
Date: June 15, 2009 05:16PM
At the worst the head only has two bent valves. The rods were stock and should hve been changed a long time ago. 25 pounds of boost on pump gas and a few hundred passes down the track was more then the rod could handle. I will be building it back up with good Crower rods this time.
(4513 posts)
Date: June 15, 2009 05:50PM
"That could all be welded..... ;-) ;-) "
Just mix up some JB Weld.... ;-D
302V8
Pete Mantell
Sidney, IL
(96 posts)
10/23/2007 09:47AM
69 MGB 302 V8 Ford 302 '347' stroker 505HP 440ftlbs
Posted by: 302V8
Date: June 30, 2009 05:38PM
Holy Cow!
Thanks for the pictures.
Pete
Bill Young
Bill Young
Kansas City, MO
(1337 posts)
10/23/2007 09:23AM
Posted by: Bill Young
Date: July 01, 2009 08:03AM
Dale, when Mr. Spooner gets your new engine going together make sure we get photos of that as well, should look a lot better! Glad you came on down to the meet anyway. Enjoyed meeting you!
tr6turbo
Dale Knapke
Sidney, Ohio
(169 posts)
08/24/2008 09:44PM
Posted by: tr6turbo
Date: July 08, 2009 09:11PM
I got the TR6 back on the road tonight. I need to get some miles on it to break in the rings before I take it back to the drag strip. I am hoping to get it on the dyno before the end of the summer. If i do I will post up some numbers.
Date: July 10, 2009 12:01AM
Glad to hear you've got it back up & running Dale. Looking forward to seeing the numbers.
