The BritishV8 Pub
lars49
Larry Barnes
Colorado Springs
(177 posts)
06/11/2009 02:12PM
1980 MGB GM LA1 3400 V6
Pikes Peak Toll road rules
Posted by: lars49
Date: June 30, 2014 09:56PM
We had a death Sunday during the Pikes Peak Hill Climb event. That got me thinking that I should post the rules for the toll road. Although it is within the Pike National Forest the toll road is owned and maintained by the City of Colorado Springs. Here are the rules from their web page regarding the toll road.
To make your trip more pleasant, review these hints and techniques. Take your time and enjoy the drive. The trip to the summit and back is 38 miles. Please plan on a minimum of 2-hours for the round trip drive and have at least a half of tank of gas. We recommend that you drive up to the summit and save picture stops and points of interest for the drive down, this will be easier on your vehicle.
  • Speed Limit is 25mph unless otherwise posted;
  • Uphill traffic has the right of way at all times; - Colorado State Motor Vehicle Regulation
Ascending the Mountain:
  • Drive the first two miles past the tollgate in low gear or the low range to allow your vehicle to operate properly.
  • Drive easy grades and short level stretches in intermediate gears to keep your vehicle from overheating.
  • Roll down the windows and let the fresh air in. Please Do Not run your air conditioner while driving uphill, this may cause your engine to overheat.
  • If you vehicle starts to labor on grades, shift to a lower gear to maintain constant speed. This will assist in keeping your engine cooler. Shift automatics manually into a lower range to lock in the gear.
  • Please stay on your side of the road, including the straight stretches and the curves. Please DO NOT CUT THE CORNERS
  • If your vehicle is slowing other traffic, please pull off at a turnout to let them pass. Your courtesy will be appreciated.
  • If you overtake slower moving traffic, please pass Only in areas where there is sufficient visibility. DO NOT PASS ON BLIND CURVES.
  • Upon reaching the summit, run your engine at a fast idle for a few minutes to reduce overheating.
Descending the Mountain:
  • Drive down the mountain in low gear or low range. Let your transmission do the work. Save your brakes.
  • Apply brakes firmly to reduce speed. Applying continuous pressure to the brakes causes excessive heat in the brake system. Overheated brakes will fade or fail.
  • Stay on your own side of the road at all times -do not cut corners.
  • Uphill traffic has the right-of-way at all times. Be prepared to give it a "brake".
  • As a courtesy to descending visitors, the Pikes Peak Highway Rangers conduct a brake check at Glen Cove during peak periods. They will check the temperature of your brakes for excessive brake heat. Your safety is our concern as well as yours.
  • If other motorists wish to pass, let them do so. Use a turnout or wide spot to allow them to pass.
Stopping:
  • Use the turnouts provided for stopping.
  • If you must stop at any place other than a turnout, do it on a straight where your vehicle is plainly visible to other motorists.
  • If you plan to leave your vehicle for long periods, leave a visible note concerning your plans and general location.
  • Wedge rocks under the downhill sides of your vehicle wheels to prevent rolling.
  • Overnight parking on Pikes Peak is prohibited. Return to your vehicle prior to closing times posted.
Overheating:
  • If your engine is hot, run it at a fast idle. Consult your driver's manual for proper cooling procedures.
  • You may wish to run water on your radiator core to condense steam and reduce heat.
  • Do NOT remove the radiator cap until the engine is cool. Follow the manual procedures when adding water or other coolants.
Edited 2 time(s). Last edit at 06/30/2014 10:00PM by lars49.
Re: Pikes Peak Toll road rules
Date: July 01, 2014 12:56AM
Here's an interesting news article about the accident:
Bobby Goodin dies following bizarre and horrific motorcycle accident at Pikes Peak
burner1
Gary W
(212 posts)
09/24/2011 09:59AM
Posted by: burner1
Date: July 02, 2014 03:29PM
I went to Pikes Peak last year. Watched some practicing the day before the race and the race. It is uncomfortable where the spectators are in many places. I sat on a big rock I could get behind. Cold in the morning.
If you mess up at pikes peak, especially at altitude, you become an airplane without wings!
lars49
Larry Barnes
Colorado Springs
(177 posts)
06/11/2009 02:12PM
Posted by: lars49
Date: July 02, 2014 05:38PM
One other note - for the Peak and a lot of the mountain roads - NO GUARD RAILS
(4514 posts)
Date: July 02, 2014 07:32PM
Rule #1 Stay on the roadway!
Oldbloke
Jim Legg
Napa, California
(94 posts)
01/24/2013 03:24PM
1970 Rover P6 3500S Rover 3.5L V8
Posted by: Oldbloke
Date: July 02, 2014 07:52PM
If yer too scared to drive it, ya can always take the cog wheel train out of Pagosa Springs...!
burner1
Gary W
(212 posts)
09/24/2011 09:59AM
Posted by: burner1
Date: July 03, 2014 09:21AM
I'm only too scared to drive it while the race is going on.
http://www.rc-tech.net/cars2/PP.jpg
http://www.rc-tech.net/cars2/PP2.jpg
lars49
Larry Barnes
Colorado Springs
(177 posts)
06/11/2009 02:12PM
Posted by: lars49
Date: July 03, 2014 11:06AM
Jim - That's Manitou Springs
Oldbloke
Jim Legg
Napa, California
(94 posts)
01/24/2013 03:24PM
Posted by: Oldbloke
Date: July 03, 2014 02:15PM
Yeah, I knew that, CW McCall and 'Wolf Creek Pass' been running through my head with its reference to Pagosa Springs. One of my bros used to live in Manitou Springs to boot..!
TR-4rd
Jay Smith
Kansas City, MO
(5 posts)
06/17/2013 12:04AM
1963 TR4 5.0L Ford V8
Posted by: TR-4rd
Date: July 11, 2014 10:12AM
You can always make your way up Pike's Peak the way I did last summer!
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: July 11, 2014 05:25PM
Why do I get the feeling that coming down was the hard part....unless you've got some good ventilated disc brakes on that contraption.
TR-4rd
Jay Smith
Kansas City, MO
(5 posts)
06/17/2013 12:04AM
Posted by: TR-4rd
Date: July 14, 2014 12:03PM
Coming down was definitely NOT the hard part. Going up nearly killed me though. :-)
