Useful Tools
Thought I would see if there is any interest in starting a thread of helpful tools. This would provide a spot to share, store and discuss helpful hand tools, software, apps and websites. I will start it out with a link to Dan Masters Speed-RPM calculator which I can host from my Google Drive which is another useful tool. I also converted the spreadsheet to Google Sheets which is free if you dont have access to Microsoft Excel.
I also added a version of the spreadsheet that allows the you to input the actual tire diameter instead of the program doing it. The 205/50-15, according to Tire Rack measurements, can vary from 22.8" to 23.2". The spreadsheet was done by Dan Masters per Carl's request Both versions are below in Google Sheets and Microsoft Excel Google Sheets version of Dan Masters Speed-RPM calculator [drive.google.com] Microsoft Excel version of Dan Masters Speed-RPM calculator [drive.google.com] ---------------------------------------------------------------------------------------------------------------------------------------------------------------- Google Sheets version of Dan Masters Speed-RPM calculator - Allows Actual Tire Diameter to be input [docs.google.com] Microsoft Excel version of Dan Masters Speed-RPM calculator - Allows Actual Tire Diameter to be input [drive.google.com] Edited 2 time(s). Last edit at 10/12/2018 03:27PM by v8mgb. |
Re: Useful Tools
Here is an article on the top 20 things to buy from Harbor Freight. It’s where I get my nitrial gloves from.
[www.familyhandyman.com] |
Re: Useful Tools
Lifts for 8' ceiling garages (like mine).
Triumph C7000 [nationalautotools.com] MaxJax [www.maxjaxusa.com] QuickJack [www.quickjack.com] Kwik-Lift [www.kwik-lift.com] EZcarlift [ezcarlift.com] |
Re: Useful Tools
Has anyone converted there T12 florescent shop lights to LED? Wondering what the best approach is. A quick cost comparison shows the link below is the lowest cost per lumen vs installing LED lights into my existing florescent fixtures.
[www.amazon.com] Edited 1 time(s). Last edit at 10/12/2018 10:12PM by v8mgb. |
Re: Useful Tools
Jim, those are good lights and that is a very good price. I have installed them in the house as indirect lighting and in the tin carport which is being set up for paint work. Considering them for the main shop as well. They daisy chain nicely. I had one bad out of 18 and it was easy to repair.
Easy to install. Mount 2 clips with screws. then clip and plug in. Jim |
Re: Useful Tools
They should be available in warm white.
Re: Useful Tools
More research, Another way to convert a standard florcent light fixture is to use “ballast bypass” bulbs. Basically the ballast is taken out of the circuit and the neutral and hot wires are connected to terminals on one end of the bulb. Need to make sure the socket you wire up to hot and neutral is not shunted. This appears to be the lowest cost with 4’ bulbs as low as $5 each.
For the garage I will most likely use the solution from Amazon. For a large room like the garage I would like to spread the light sources out. For my basebent shop I think I will probably use ballast bypass bulbs and reuse the existing fixtures. Prices for LED’s will most likely continue to drop. |
Re: Useful Tools
Here are a couple of tools I inherited from my father-in-law that I think are really useful. This first picture shows a floor rinsing tool. You use it with a hose and it has nozzles that spray down and in a concentrated area so you can get close to things you aren't moving without getting them and the walls wet.
This next one is a made in the USA Rubbermaid dust pan from the 60s. I'm sure there are good ones out there still but I haven't run across them. When you sweep stuff into this thing, very little of the dust goes under it so it makes the job so much easier....I like it. By the looks of my floor I need to use both of them soon! :) |
Re: Useful Tools
Jim, good idea, I was going to think of it later but you beat me to it.
I have purchased a new air compressor, so quiet you can stand next to the compressor and talk normal. This thing is "morgue at 3 am" quiet. I think it is the one supplied by California Air, I got mine at HD. I don't work for either or gain from either. charles Edited 1 time(s). Last edit at 03/19/2021 09:28AM by MGBV8. |
Re: Useful Tools
Especially useful for cleaning the underside, rust proofing, suchlike messy things one doesn't want to do in the garage, this giant jack
[newatlas.com] Just watch out for oil escaping from the engine, that wouldn't be so funny. $1,000 if you're brave right now, on Kickstarter. Ivor |
Re: Useful Tools
Harbor Freight Tools Coupon Database
Love or hate the HF its all about the coupon. This is a link to searchable database and allows you to search for the item your interested in pull up a picture of the coupon on your phone. It also has all the coupons for the free stuff My local HF accepts a picture of the coupon. Put the link on your phone and your set. [www.hfqpdb.com] |
Re: Useful Tools
This type of flex 24" long hose clamp tool is great for hard to get to none geared clamps. There are opposing schools of thought regarding geared vs spring pressure clamps. Geared has sub categories( std. and full circle EFI). Spring clamps are said to hold a constant pressure as the rubber softens and not require re-tightening. At least that is Jaguars position. :-)
E-Bay seller listing, no affiliation Picture Information 24-034-inch-Long-Reach-Flexible-Hose-Clamp-Pliers-Locking-Tool-Fuel-Oil-Water-Hose 24-034-inch-Long-Reach-Flexible-Hose-Clamp-Pliers-Locking-Tool-Fuel-Oil-Water-Hose 24-034-inch-Long-Reach-Flexible-Hose-Clamp-Pliers-Locking-Tool-Fuel-Oil-Water-Hose 24-034-inch-Long-Reach-Flexible-Hose-Clamp-Pliers-Locking-Tool-Fuel-Oil-Water-Hose 24-034-inch-Long-Reach-Flexible-Hose-Clamp-Pliers-Locking-Tool-Fuel-Oil-Water-Hose 24-034-inch-Long-Reach-Flexible-Hose-Clamp-Pliers-Locking-Tool-Fuel-Oil-Water-Hose Details about 24" inch Long Reach Flexible Hose Clamp Pliers Locking Tool Fuel Oil Water Hose Edited 1 time(s). Last edit at 03/19/2021 09:29AM by MGBV8. |
Re: Useful Tools
Here's a cool tool I recently got. $15 on Amazon - it's effectively a bore scope that uses your phone for the display & can snap pics &/or capture video. I haven't used it on the car yet, but will capture some video when I do. I did use it to figure out what was behind a section of wall & it worked great for that.
You have to have a newer phone. The link below is the one I got; it works with Android phones that have a USB-C connector. I've also seen versions that work with newer iPhones. [www.amazon.com] 3/17/19 - Thought I'd post an update on this thing. It can be a bit hard to manuver but once you get the hang of it, it works reasonably well. I needed to figure out if my trans to bell housing bolts had nuts or went into threaded holes. I was able to see all four bolts pretty well. Here's a sample pic showing the resolution... Edited 1 time(s). Last edit at 03/17/2019 02:20PM by rficalora. |
Re: Useful Tools
I upgraded the garage lights to LED finally. Purchased these from Amazon. Good reviews, these are the lowest cost per lumen and I like that the light can be spread out vs being concentrated in one area like a typical florescent fixture.
I purchased two sets (12 lights) I have 3 lights on both sides and three down the center and a row of three across the front. One additional advantage of LED lights in the garage is they are not effected my cold temperatures. There are several color temperatures available, I went with the 6500K which that call daylight. The color temperature is good. Its a very easy install. I did need to purchase drywall anchors. [www.amazon.com] |
Re: Useful Tools
The prices go up and down on those. I used them in my carport/shed/paint booth and they put out a lot of light. Very happy with them, I bought the warm white.
