Links to detailing products from Trilogy session
I don't know if these got posted, so here they are again:
[www.detailedimage.com] Coupon Code: DetailedImage9843 Drying towels - The Gauntlet which I showed at the shop [www.detailedimage.com] The Slurpy- This is a small family owned operation out of Dallas TX. Their entire product line is GREAT and customer service EXCELLENT! For the month of June use code GASMONEY. If you're going to use these for your V8 and your daily drivers the perfect combo is 2 full size and 4 Jr. The Jr also make excellent t glass towels! [aqualuxdetail.store] Microfiber detergent- Use 1-2 foz per load. Do not mix with other fabrics. Must air dry or dry below 120 degrees. [www.detailedimage.com] Rinseless wash- [www.detailedimage.com] Mix 4 caps to 4 gal of water to wash Mix 2 caps ± distilled water in 32foz bottle for quick detailer, glass cleaner, interior dusting Mix 3 caps + distilled water into 32foz bottle for claybar lubricant Iron Remover- Here are two excellent choices. This is the magic juice that turns purple and removes Iron deposits. [www.detailedimage.com] Synthetic claybar- Special must be taken when storing these that the black rubbery surface is placed face up and not allowed to touch anything. It will stick to whatever you place it against and ruin it. This is a great hand application [www.detailedimage.com] This works great for both hand and machine application [www.detailedimage.com] Cheers, James Browne Trilogy Detailing 336-940-8111 21 Golf Course Rd Sparta, NC 28675 |
