Finally!!!!
Its up and I am partially moved into my new 26'x30' garage. Unfortunately though a TR6 for a new harness and a 57 Thunderbird has beat my TR8 for occupancy. I do however have the walls covered just to give it that homey feel. A loft is coming and then a 2-post lift!
[/URL] [/URL] [/URL] |
Re: Finally!!!!
Might look empty now, but just wait!
Re: Finally!!!!
Looks great Mike! I like how you kept the ceiling high. Plans for a lift? My ceiling is only 8' - I've been reading up on what it'd take to revise it. Seems like it's a pretty big job. You were definitely smart to build it that way from the outset!
Re: Finally!!!!
I am doing insulation and eventually drywall. Two post lift yes! Since the bottom of the ceiling is 13'-3"
Re: Finally!!!!
13'? Great. I was trying to guess based on the height above the garage doors plus the raised ceiling. It's higher than I thought.
Re: Finally!!!!
I have 8' tall garage doors and the walls are 11'. I have TWO 240v 8 and 6 gauge lines run out to the garage. I'm ready for the lift, compressor and welder.
Re: Finally!!!!
Garage looks awesome did you make sure your floor is thick enough for the lift
Re: Finally!!!!
It's a 5 inch slab with two grade beams 24" wide x 16" deep right where the lift will go.
