Re: British V8 2014 Registrations List
If everyone who plans to attend would take a moment to phone and encourage a friend or two, I've no doubt we could double the registrations. Even if you can't make it this year, please take a moment to encourage your friends to participate.
A lot of people have filled out their registration forms, but not yet sent them in.
If you're not sure whether your wife will join you - mail the form today! - and amend it later. Your registration will encourage others. |
Hey Curtis,
You need to move that Red dot in Washington a little to the left and up closer to Canada ;-p LOL Bill Edited 1 time(s). Last edit at 06/24/2014 08:38PM by MG four six eight. |
lars49 Larry Barnes Colorado Springs (177 posts) Registered: 06/11/2009 02:12PM Main British Car: 1980 MGB GM LA1 3400 V6 |
You can add another dot to Cali - I got Jim Legg's form. I will also be getting 2 more from the great white north, that is after the postal dog sled get's here ;-)
I see that the map won't let you place the dots except in the middle of the state. I wish I did get to start in Nashville. ;)
Edited 1 time(s). Last edit at 07/13/2014 10:00PM by MGBV8. |
I feel your pain Carl.
I'll be racing to get my car ready... Put it up on stands yesterday to check things out just as a precaution and found one of my CV boots was split and grease had been slung all over. Pulling the axle today - hopefully it's just the boot and I'll be able to get a replacement locally. |
Oldbloke Jim Legg Napa, California (94 posts) Registered: 01/24/2013 03:24PM Main British Car: 1970 Rover P6 3500S Rover 3.5L V8 |
All mechanical issues appear okay. Last week my CD player broke...now the seven speakers with subwolfer and two power amps have to just play the radio!!
Jim - at least you have a radio... I was planning to install my sound system this weekend, but got side tracked when I found the CV boot split. Got the axles out yesterday. Lot's of grease still in it so expect the joint will be ok. New boots should be ready for pick-up at my local parts place by the time I get off work. Hope to get them put back together tonight. If so, might still get the stereo installed before I head out.
UPDATE: Took the CV's apart; didn't put them back together because wanted to check to be sure what I was seeing wasn't abnormal (see pics). DriveShaft Shop confirmed normal so will be putting them back together tonight or tomorrow. Note the little dents in each opening... all 6 openings on both axles had these dents so I was pretty sure they weren't wear marks; The DriveShaft Shop confirmed ok... Note the horizontal "scoring" and shiney wear areas... Again, confirmed as normal wear. Horizontal lines are from machining the cage & sihiney area is wear from CV going through it's motion... Edited 1 time(s). Last edit at 07/15/2014 05:02PM by rficalora. |
