The BritishV8 Pub
Question for the engineers in the group...
Date: August 13, 2017 12:08PM
Planning help to get the lift I got off the trailer got me thinking... Seems I often have heavy stuff to unload. Have looked at gantry cranes but really don't want the floor space used up. If I were to suspend the I-beam from my ceiling joists with U-bolts, about how much weight could I safely load/unload with it? ceiling joists are 2x12's on 16" centers and span the 24' width of the garage.
mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
1974.5 MGB/GT 3.9l Rover
Re: Question for the engineers in the group...
Posted by: mowog1
Date: August 13, 2017 05:58PM
You're going to be installing a two-post lift.
Can you use one of the arms to lift the load from the bed of the truck for future heavy items?
Date: August 13, 2017 06:31PM
OK, using the lift is obvious now. Just need to be sure the load is balanced on the arm(s). Now my question just sounds silly!
Mickey Richaud
Mickey Richaud
Townsend TN
(198 posts)
08/25/2015 06:36AM
'03 Jaguar XK8 Jaguar 4.2
Posted by: Mickey Richaud
Date: August 14, 2017 06:49AM
"Now my question just sounds silly!"
Congrats on the lift!
Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Posted by: Jim Stabe
Date: August 14, 2017 09:24AM
If you support the 2x12 with a temporary brace from the floor just far enough from the wall to let the trailer in, it will support enough to unload the lift components. You could also double up the 2x12 in that span if you are uncomfortable.
(6569 posts)
Date: August 14, 2017 11:17AM
Another option is to lay a 4x4 on top and perpendicular to and spanning 4 or more of the joists, then suspend your lifting device from that, and this should easily provide adequate support for lifting most common loads up to 500 lbs or so, maybe double that depending on how you do it.
Dan B
Dan Blackwood
South Charleston, WV
(1009 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: August 14, 2017 11:43AM
This could help:
[diy.stackexchange.com]
Date: August 14, 2017 12:58PM
Thanks all. Rick's post has the answer though. I was thinking like a guy who doesn't have a lift... but now I do :)
kstevusa
kelly stevenson
Southern Middle Tennessee
(986 posts)
10/25/2007 09:37AM
Posted by: kstevusa
Date: August 14, 2017 02:07PM
Rob, cranial gas? Ha Ha
(6569 posts)
Date: August 14, 2017 06:55PM
I just thought you were figuring out how to unload and erect the lift.
