rficalora Rob Ficalora Cypress, TX (2429 posts) Registered: 10/24/2007 02:46PM Main British Car: '76 MGB w/CB front, Sebring rear, early metal dash Ford 302 |
Anyone familiar with motor wiring?
I had to move my 7.5hp, 80 gallon compressor to the new house myself. With the come-alongs I had & the size of my garage rafters, I had to remove the pump & motor to lift it onto the trailer... thought I took a picture of the wiring but I either remember wrong or accidentally deleted it :(. Most of the wires are clear, but two are not. When I wired it the way I thought it went, the motor buzzed loudly when I turned it on. (Shut it off pretty quickly so hope nothing got damaged.)
Below is a picture of the wiring. I'm assuming the R1's & B1's get tied together (respectively). I thought both the smaller yellow wires (T5 & 8?) were tied together with one of the power legs, but per above, that's not right. Anyone know where those go? Goal is to have motor work & spin counter clockwise. Have googled a bit but haven't found a diagram (motor is a Leeson 7.5Hp single voltage (220); single phase motor) Edited 1 time(s). Last edit at 01/25/2018 02:53PM by rficalora. |
Jim Stabe Jim Stabe San Diego, Ca (636 posts) Registered: 02/28/2009 10:01AM Main British Car: 1966 MGB Roadster 350 LT1 Chevy |
Re: Anyone familiar with motor wiring?
I know it's not helping but I always make some tape flags to mark wires when I have to take them apart. Have yuu tried the manufacturer?
74ls1tr6 Calvin Grannis Elk Grove,CA (1126 posts) Registered: 11/10/2007 10:05AM Main British Car: 74 TR6 / 71 MGB GT TR6/Ls1 71 MGB GT/Ls1 |
[www.doityourself.com]
Maybe this will help. So maybe R1 to R1 B1 to B1 5 to R1 8 to B1 or switch 5 and 8 if it is not going in ccw rotation? The buzzing you had I think, the motor didn't know what way to rotate being tied together on one leg. Edited 2 time(s). Last edit at 01/25/2018 06:59PM by 74ls1tr6. |
That was it Calvin! It's working again. Thanks.
Edited 1 time(s). Last edit at 01/25/2018 09:22PM by rficalora. |
Charles Charles Long McDonald, TN (159 posts) Registered: 09/15/2013 08:54AM Main British Car: 1966 MGB V6 1994 Camaro 3.4L 60V6 |
Rob, Leeson motors are sold buy Northern Tools. I found a diagram on there site, might look there. Another thought, there may be a diagram on the box cover.
regards charles |
billymgb1000 bill gaulin harrisville R.I. (65 posts) Registered: 11/30/2012 12:31AM Main British Car: 1974 MGB V8 LS1 5.3 |
Calvin You da man!!!!
