The BritishV8 Pub
wirewheels
Brian Induni
POrtland, OR
(4 posts)
05/28/2013 05:19PM
Keep stock speedo or change to electronic?
Posted by: wirewheels
Date: April 30, 2018 08:32PM
In the name of market research, I'm wondering if the majority of people would rather keep their stock speedo or change to electronic when dong an engine / gearbox swap?
Thanks for the feedback!
Spitfire 350
Phil McConnell
Perrysburg, OH (Toledo area)
(180 posts)
01/11/2010 09:19PM
74 Spitfire 350Chevy
Re: Keep stock speedo or change to electronic?
Posted by: Spitfire 350
Date: May 01, 2018 12:32PM
I like the electronic.
(2511 posts)
Date: May 01, 2018 07:43PM
Me too. Made it easy to reset to read accurately when I changed tire size.
(4369 posts)
Date: May 02, 2018 08:54AM
I'd rather change all the gauges, and install a custom dash. That approach seems especially popular among owners of "Abingdon pillow" dashboards.
74ls1tr6
Calvin Grannis
Elk Grove,CA
(1142 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: May 02, 2018 10:06PM
I'm another one that likes the electronic gauges, very easy to work with, and seem to be accurate.
MG four six eight
Bill Jacobson
Wa state
(279 posts)
10/23/2007 02:15AM
Posted by: MG four six eight
Date: May 02, 2018 10:35PM
I prefer electronic also. It's way easier to route wires compared to routing a speedometer cable. They can be calibrated with a push of a button and best of all there's no bouncing needle due to a sticking cable!
(5566 posts)
Date: May 03, 2018 10:24AM
Well I did something a bit different and am very happy with the results. (Pillow dash originally which I stripped, recovered with black leather, and refitted with a glove box and the early, larger gauges.) It turns out that the series-III ('85 or so) Jaguar XJ6 used the same size speedometer. It is not cable driven, but is fitted with a small motor on the back. At the transmission a small generator attaches at the usual location and a couple of wires connects the two. So I bought a used, good condition speedo on ebay and a new sender and installed them. The speedo goes to 140, which puts 70mph at the top of the dial.
The bezel was different so I fitted one from an early MGB speedo. The mounting was also different, a push and twist arrangement which I adopted but without the wavy spring. And of course I had already converted the MGB tach long ago.
It does have the typical needle sweep of the electronic speedos on power-up, and occasionally does not read below 10mph until the car has moved faster than that. I suspect there may be a little stickiness in the internal lubricants. Otherwise it is dead accurate and calibrated in the usual way by changing the gears. I did have to re-cut the threads on the transmission plug-in to match the sender.
(1259 posts)
What if the Hokey Pokey really is what it's all about?
Date: May 03, 2018 12:53PM
Your speedo drive might not be well suited to this crowd Brian.
We are more interested in modifying our vehicles rather than keeping them stock appearing.
The early british cars in particular lend themselves well to swapping out the round gauges for aftermarket offerings
If I had something with a more unique speedo your product would be a good choice.
Much like my 62 impala ss. 496 BBC with a 6 speed C5 drivetrain and suspension.
I might be contacting you when I get further along.
Live like you mean it.
(3433 posts)
79 MGB, Buick 215
Date: May 03, 2018 07:16PM
I have kept all my stock gauges, Brian. I have also considered swapping them. :)
302GT
Larry Shimp
(188 posts)
11/17/2007 01:13PM
Posted by: 302GT
Date: May 24, 2018 09:24AM
Beware of aftermarket gauges! I originally put in electronic VDO gauges but the car out accelerated both the tachometer and speedometer. I changed to SpeedHut gauges which solved the problem. Try the original gauges if you can, I suspect mechanical speedometer, at least, will never lag.
jjohanski
James Johanski
(12 posts)
11/15/2017 08:57AM
Posted by: jjohanski
Date: June 15, 2018 03:50PM
How about using a Speedhut Speedbox to drive the mechanical speedometer.
wirewheels
Brian Induni
POrtland, OR
(4 posts)
05/28/2013 05:19PM
Date: June 15, 2018 06:04PM
@jjohanski - Well, you could but that would be counter to my desire to have people use Classic Speed! [www.classicautoinnovations.com]
Oh, and we hold the patent for driving a mechanical speedometer via GPS ;-)
(U.S. Patent No. 9,802,487) [patents.google.com]
