The BritishV8 Pub
v8mgb
Jim Miller
(80 posts)
01/01/2008 11:38AM
78 MGB Buick 215
Useful Tools
Posted by: v8mgb
Date: October 09, 2018 03:07PM
Thought I would see if there is any interest in starting a thread of helpful tools. This would provide a spot to share, store and discuss helpful hand tools, software, apps and websites. I will start it out with a link to Dan Masters Speed-RPM calculator which I can host from my Google Drive which is another useful tool. I also converted the spreadsheet to Google Sheets which is free if you dont have access to Microsoft Excel.
I also added a version of the spreadsheet that allows the you to input the actual tire diameter instead of the program doing it. The 205/50-15, according to Tire Rack measurements, can vary from 22.8" to 23.2". The spreadsheet was done by Dan Masters per Carl's request
Both versions are below in Google Sheets and Microsoft Excel
Google Sheets version of Dan Masters Speed-RPM calculator
[drive.google.com]
Microsoft Excel version of Dan Masters Speed-RPM calculator
[drive.google.com]
Google Sheets version of Dan Masters Speed-RPM calculator - Allows Actual Tire Diameter to be input
[docs.google.com]
Microsoft Excel version of Dan Masters Speed-RPM calculator - Allows Actual Tire Diameter to be input
[drive.google.com]
Edited 2 time(s). Last edit at 10/12/2018 03:27PM by v8mgb.
v8mgb
Jim Miller
(80 posts)
01/01/2008 11:38AM
78 MGB Buick 215
Re: Useful Tools
Posted by: v8mgb
Date: October 11, 2018 10:38AM
Here is an article on the top 20 things to buy from Harbor Freight. It’s where I get my nitrial gloves from.
[www.familyhandyman.com]
(3601 posts)
79 MGB, Buick 215
Re: Useful Tools
Date: October 11, 2018 11:24AM
Lifts for 8' ceiling garages (like mine).
Triumph C7000
[nationalautotools.com]
MaxJax
[www.maxjaxusa.com]
QuickJack
[www.quickjack.com]
Kwik-Lift
[www.kwik-lift.com]
EZcarlift
[ezcarlift.com]
RMO 699F
Mike Maloney
SW Ohio
(513 posts)
12/09/2007 12:28PM
MGB Sebring GT, Arkley Spriget, Lotus 7 Stalker 3.9 Rover, 1275cc, 3.4 V6
Re: Useful Tools
Posted by: RMO 699F
Date: October 11, 2018 07:40PM
Very interesting Jim!
v8mgb
Jim Miller
(80 posts)
01/01/2008 11:38AM
78 MGB Buick 215
Re: Useful Tools
Posted by: v8mgb
Date: October 12, 2018 03:33PM
Has anyone converted there T12 florescent shop lights to LED? Wondering what the best approach is. A quick cost comparison shows the link below is the lowest cost per lumen vs installing LED lights into my existing florescent fixtures.
[www.amazon.com]
Edited 1 time(s). Last edit at 10/12/2018 10:12PM by v8mgb.
(5725 posts)
Re: Useful Tools
Date: October 12, 2018 05:21PM
Jim, those are good lights and that is a very good price. I have installed them in the house as indirect lighting and in the tin carport which is being set up for paint work. Considering them for the main shop as well. They daisy chain nicely. I had one bad out of 18 and it was easy to repair.
Easy to install. Mount 2 clips with screws. then clip and plug in.
v8mgb
Jim Miller
(80 posts)
01/01/2008 11:38AM
78 MGB Buick 215
Re: Useful Tools
Posted by: v8mgb
Date: October 12, 2018 10:16PM
Thanks Jim. I think I will do the 8 pack.
(3601 posts)
79 MGB, Buick 215
Re: Useful Tools
Date: October 14, 2018 11:31AM
6500K is likely going to have a blueish tint.
(5725 posts)
Re: Useful Tools
Date: October 14, 2018 12:12PM
They should be available in warm white.
(3601 posts)
79 MGB, Buick 215
Re: Useful Tools
Date: October 14, 2018 02:24PM
4000K is better, IMO.
v8mgb
Jim Miller
(80 posts)
01/01/2008 11:38AM
78 MGB Buick 215
Re: Useful Tools
Posted by: v8mgb
Date: October 14, 2018 07:05PM
More research, Another way to convert a standard florcent light fixture is to use “ballast bypass” bulbs. Basically the ballast is taken out of the circuit and the neutral and hot wires are connected to terminals on one end of the bulb. Need to make sure the socket you wire up to hot and neutral is not shunted. This appears to be the lowest cost with 4’ bulbs as low as $5 each.
For the garage I will most likely use the solution from Amazon. For a large room like the garage I would like to spread the light sources out. For my basebent shop I think I will probably use ballast bypass bulbs and reuse the existing fixtures. Prices for LED’s will most likely continue to drop.
Scott68B
Scott Costanzo
Columbus, Ohio
(537 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Re: Useful Tools
Posted by: Scott68B
Date: October 14, 2018 08:55PM
Here are a couple of tools I inherited from my father-in-law that I think are really useful. This first picture shows a floor rinsing tool. You use it with a hose and it has nozzles that spray down and in a concentrated area so you can get close to things you aren't moving without getting them and the walls wet.
This next one is a made in the USA Rubbermaid dust pan from the 60s. I'm sure there are good ones out there still but I haven't run across them. When you sweep stuff into this thing, very little of the dust goes under it so it makes the job so much easier....I like it. By the looks of my floor I need to use both of them soon! :)
Charles
Charles Long
McDonald, TN
(177 posts)
09/15/2013 08:54AM
1966 MGB V6 1994 Camaro 3.4L 60V6
Re: Useful Tools
Posted by: Charles
Date: January 21, 2019 08:54PM
Jim, good idea, I was going to think of it later but you beat me to it.
I have purchased a new air compressor, so quit you can stand next to the compressor and talk normal.
This thing is "morgue at 3 am" quiet.
I think it is the one supplied by California Air, I got mine at HD.
I don't work for either or gain from either.
charles
v8mgb
Jim Miller
(80 posts)
01/01/2008 11:38AM
78 MGB Buick 215
Re: Useful Tools
Posted by: v8mgb
Date: January 21, 2019 11:42PM
A quiet compressor would be nice! I have a loud one.
88v8
Ivor Duarte
Gloucestershire UK
(618 posts)
02/11/2010 04:29AM
Re: Useful Tools
Posted by: 88v8
Date: February 11, 2019 01:27PM
Especially useful for cleaning the underside, rust proofing, suchlike messy things one doesn't want to do in the garage, this giant jack
[newatlas.com]
Just watch out for oil escaping from the engine, that wouldn't be so funny.
$1,000 if you're brave right now, on Kickstarter.
Ivor
v8mgb
Jim Miller
(80 posts)
01/01/2008 11:38AM
78 MGB Buick 215
Re: Useful Tools
Posted by: v8mgb
Date: February 14, 2019 12:47PM
Harbor Freight Tools Coupon Database
Love or hate the HF its all about the coupon. This is a link to searchable database and allows you to search for the item your interested in pull up a picture of the coupon on your phone. It also has all the coupons for the free stuff My local HF accepts a picture of the coupon. Put the link on your phone and your set.
[www.hfqpdb.com]
kstevusa
kelly stevenson
Southern Middle Tennessee
(894 posts)
10/25/2007 09:37AM
Re: Useful Tools
Posted by: kstevusa
Date: February 14, 2019 02:51PM
This type of flex 24" long hose clamp tool is great for hard to get to none geared clamps. There are opposing schools of thought regarding geared vs spring pressure clamps. Geared has sub categories( std. and full circle EFI). Spring clamps are said to hold a constant pressure and the rubber softens and not require re-tightening. At least that is Jaguars position. :-)
E-Bay seller listing, no affiliation
Picture Information
24-034-inch-Long-Reach-Flexible-Hose-Clamp-Pliers-Locking-Tool-Fuel-Oil-Water-Hose
Details about 24" inch Long Reach Flexible Hose Clamp Pliers Locking Tool Fuel Oil Water Hose
(2573 posts)
Re: Useful Tools
Date: February 14, 2019 09:02PM
Here's a cool tool I recently got. $15 on Amazon - it's effectively a bore scope that uses your phone for the display & can snap pics &/or capture video. I haven't used it on the car yet, but will capture some video when I do. I did use it to figure out what was behind a section of wall & it worked great for that.
You have to have a newer phone. The link below is the one I got; it works with Android phones that have a USB-C connector. I've also seen versions that work with newer iPhones.
[www.amazon.com]
3/17/19 - Thought I'd post an update on this thing. It can be a bit hard to manuver but once you get the hang of it, it works reasonably well. I needed to figure out if my trans to bell housing bolts had nuts or went into threaded holes. I was able to see all four bolts pretty well. Here's a sample pic showing the resolution...
Edited 1 time(s). Last edit at 03/17/2019 02:20PM by rficalora.
