The BritishV8 Pub
Rog
Roger Haber
Hartell Southern Alberta, Canada
(6 posts)
06/20/2014 11:30PM
1967 MGB Roadster Chevy 350
Fast cars front suspension
Posted by: Rog
Date: July 04, 2020 04:08PM
I was wondering if anyone can help me out. I am wondering what ball joints Ted used on his front suspensions. He told me once, and I forgot! I need to replace the boots on mine. I contacted Senneker by email and asked them, but they never got back to me. I also need some slightly heavier springs for my QA1 shocks as mine are screwed in quite far to achieve ride height.
2.5 inches of thread showing. Can anyone help with these questions?
Roger Haber
Hartell, Alberta
Canada
kstevusa
kelly stevenson
Southern Middle Tennessee
(943 posts)
10/25/2007 09:37AM
Re: Fast cars front suspension
Posted by: kstevusa
Date: July 05, 2020 09:22AM
Roger, sent you an email with info on measuring the joints and getting Poly Boots. This showed up on our Jaguar Forums. Google __ball joint poly boots for xk8-- and click the link with Jaguar Forums. It will give several threads about getting boots from A/M sources. Hope this helps.
(2675 posts)
Date: July 05, 2020 02:16PM
I need to do the same on mine; one side is torn.
Roger, I've not researched the ball joints, but the hubs (at least the bearings) are Pontiac Fierro. Maybe the ball joints are from the same application?
kstevusa
kelly stevenson
(943 posts)
10/25/2007 09:37AM
Posted by: kstevusa
Date: July 05, 2020 03:39PM
The article I referenced were from a XK8owner who purchased his Poly boots off E-Bay from a vendor in Bulgaria. Took awhile but he was pleased. Also listed info how how to order along with measuring the 3 dimensions needed to order correctly. Jaguar Forums is not to be confused with Jaguar Forum, they are different.
MG four six eight
Bill Jacobson
Wa state
(306 posts)
10/23/2007 02:15AM
Posted by: MG four six eight
Date: July 05, 2020 11:28PM
Roger,
I believe that the uppers are Chevy Chevette, not sure about the lower ball joints though.
Bill
(3918 posts)
1979 MGB, Buick 215
Date: July 07, 2020 09:22AM
My understanding is that Fast Cars, Inc. is but a small division of Senneker Performance. They are primarily in the racing business & may be operating with a skeleton crew due to Coronavirus.
[www.sennekerperformance.com]
Rog
Roger Haber
(6 posts)
06/20/2014 11:30PM
Posted by: Rog
Date: July 07, 2020 10:01AM
Thanks Guys for all your responses. I can't believe it's this hard to get simple information. I emailed
Senneker a couple of times, and no answer. When I emailed Ted Judy answered immediately in spite of her situation.
Well hopefully someone will have the answer. Thanks again everyone, hope to see you in Auburn.
Roger
mowog1
Rick Ingram
Central Illinois
(1501 posts)
10/17/2007 09:36PM
1974.5 MGB/GT 3.9l Rover
Posted by: mowog1
Date: July 08, 2020 10:31PM
I've found that repeated attempts through phone calls and e-mails is best.
When that fails...contact one of us here via a Private Message.
Magic can happen.
Edited 1 time(s). Last edit at 07/10/2020 09:33AM by MGBV8.
(2675 posts)
Date: July 09, 2020 09:40AM
Speaking of magic, I reached out to Terry. He advised that the ball joints are:
Upper is k5292 ,. Lower is k 6273 (moog numbers)
And, in case your local auto parts place only knows how to find parts with year, make, & model, I looked on RockAuto and those correlate to the uppper & lower ball joints for a 1982 Chevy Chevette, 1.6L I4.
Putting it all together, here are the notes I have on serviceable parts on the IFS. Hope this helps.
Hub bearings - '84-88 Pontiac Fiero front hubs for bearings
-- Inner bearings - Timken L44649 (bearing) L446410 (race/cup)
-- Outer bearings - Timken LM1179 (bearing) LM11710 (race/cup)
-- Grease seal - National 1174; SKF 692447
Tighten spindle nut to 50 ft/lbs while turning hub; back nut off one full turn; tighten again while turning
hub to 10 ft/lbs; back nut 1/6 to 1/4 turn to align cotter pin.
Ball Joints - Chevy Chevette (e.g. 1982)
-- Upper: K5292 (Moog)
-- Lower: K6273 (Moog)
ALIGNMENT SPECS:
-- Camber: zero to 1/4 degree negative
-- Caster: 2-1/2 to 3-1/2 degrees positive (per FastCars; others recommend 4-1/2 degrees positive)
-- Toe: Toe In 1/32" to 1/16"
(3918 posts)
1979 MGB, Buick 215
Date: July 10, 2020 09:42AM
Thanks, Rob!
MG four six eight
Bill Jacobson
Wa state
(306 posts)
10/23/2007 02:15AM
Date: July 11, 2020 01:26AM
X2 thanks Rob!
BTW, is there a consensus for going with more positive Caster vs Fastcars recommendation?
Both of my washers are set for max positive caster which if memory serves me correctly is about 3 1/2 degrees.
Sometimes the steering feels a little light at highway speeds to me and I've thought about modifying the upper A-arm mount so I can add another washer to gain a little more positive caster.
Bill
TR6-6SPD
Ken Hiebert
Toronto Ontario
(247 posts)
04/23/2008 11:43AM
1972 TR6 1994 5.7 L GM LT1
Posted by: TR6-6SPD
Date: July 11, 2020 10:43PM
Bill,
I fabricated new upper control arms moving the ball joint 7/16" rearward, giving me 6 degrees caster.
I don't have the car on the road yet but that's what I run on my TR6 and I like it
New UCA placed on top of old. 7/16" rearward:
MG four six eight
Bill Jacobson
Wa state
(306 posts)
10/23/2007 02:15AM
Date: July 12, 2020 12:16PM
Thanks Ken, that looks good! Did you use chrome-moly, also did you have to fabricate a jig?
Bill
IaTR6
Dennis Costello
Central Iowa
(159 posts)
12/29/2007 02:53PM
'73 TR 6 '97 Explorer 5.0
Posted by: IaTR6
Date: July 12, 2020 08:37PM
Ken,
I understand the movement of the upper ball joint rearward to increase caster, however I wonder about the lower.
The trunnion and lower control arms are connected by a straight pin, and the assembly lends itself to movement
in only rotation, but not side to side. It would seem attempting to move the upper pivot (ball joint) to the rear,
a bind would be introduced into the trunnion. I don't have any idea how to include a ball joint to the bottom of
the upright, but that would allow easy caster changes. Maybe there is enough flexibility in the trunnion connection
I don't see?
Thanks,
Dennis
