For Sale 1980 TR8 Coupe
1980 Triumph TR8 Coupe
VIN-TCN160058UCF (#58 of 158) Rover V8 Color-Pageant Blue JMA Interior-Beige CAAA Build Date-8/79 5-Speed Air Conditioning Power Steering Stock with the exception of the distributor internals, emissions removed or hollowed out. New Parts; Shift Bushings, Transmission mount, Battery, Clutch, Koni Shocks/struts, Lowered Springs, ball joints, tie rods, front bushings, Replaced/fixed: Front AC/Ignition wiring harness, distributor, spark plug wires, fuse box, carpet, trunk matting, TR8 alloys, Alternator, used falcon stainless steel exhaust system, 3.08 Rear from another TR8 coupe, clutch master & slave cylinders, fresh air duct, air cleaners assemblies, door seals, non-EGR drivers exhaust manifold, rear brakes, seats recovered and rear shelf. Missing/required: TR8 Coupe battery box, window regulator drivers side (have one) headliner (have one NOS), door latch on drivers door, radio, and tires. Body: 1 repaint due to accident NOS Hood, front right fender & headlamp/header panel. Frame rails and inner panels not damaged from accident. Needs rust repairs to the lower rear passenger side inner and outer panel (black portion), inner wheel arch/splash panel at pedals has a 1-inch hole, spare tire along bottom seam, blisters at rear window panel area, small dents from daily use. $4,500.00 firm |
Re: For Sale 1980 TR8 Coupe
Recently fixed:window regulator & door latch on drivers door
I wish it was that simple!
SOLD!
