Black P-38 Mike Caldwell Kentucky (51 posts) Registered: 09/18/2008 12:56AM Main British Car: None Squirrel Cage & 2 Squirrel |
Interim(?) type timing cover and damper/serpentine crank pulley from 4.0...
Hey Guys,
I hope I'm describing this correctly... Interim(?) type timing cover and damper/serpentine crank pulley from a running 4.0...This front cover is the casting with the gerotor crank driven oil pump but still has the extended upper segment with the distributor recess boss cast in but the bottom isn't open, it's like a cylindrical "pocket" where the dizzy would go. I believe this type of cover can be used for those who wish to have the better, more reliable crank driven pump but still prefer to run a distributor rather than a CPU based ignition, (like for a carbureted application), while enjoying the added benefit of a serpentine drive thanks to the matching damper/ serp pulley. I'm posting a couple pics I found to show what it is. I still need to take a few of my particular pieces but these will help identify what I'm talking about... If anyone has an interest in the pieces I have... I will be selling both the cover and damper with crank bolt and washer for $150, shipped FREE to the US via Priority Mail. Check back for pictures of my actual used pieces... THANKS! Mike Caldwell 541-808-1182 |
Re: Interim(?) type timing cover and damper/serpentine crank pulley from 4.0...
Part # on cover is HOBOURN HE1310074
Price reduced to $135 shipped to the lower 48 states. That's for the timing cover, damper and crank bolt with heavy washer. Thanks, Mike 541-808-1182 |
