Posted by:
Dave
Date: December 27, 2010 12:20PM
This is an NOS Alloy flywheel for a Buick 300 engine and includes a new clutch assy. It will also fit 340's and 350's but will NOT fit 215's or Rover V8's. It includes a brand new pressure plate and friction disc. It has 166 teeth on the ring gear and takes a 9.5 pressure plate but is drilled for others including GM 10.5" for some reason. It has no markings so I don't know who manufactured it but it is externally balanced. I called Mark LaGrou this morning and he confirmed that it should be for a Buick 300 based on 166 teeth on the ring gear but added that, as with any flywheel swap, the rotating assy should be balanced to specs. He added that there were many permutations of this engine and that he is not advocating it's use on ANY engine nor do I. I bought it for my car but found a Schiefer FW and used it instead. It was bolted up but never used. $150 shipped anywhere in the lower 48.
Edited 1 time(s). Last edit at 12/27/2010 08:45PM by Moderator.
