Rover 4.6 long block for sale.....RV8 headers also.
have a Rover 4.6 long block for sale. Usual machine shop procedures followed. Liners were replaced with flanged "top hat" liners. rotating assembly balanced. Crank ground to 10-10. Heads rebuilt and reworked to use a .488 cam.
Also have a set of RV8 ceramic coated headers ...these are big bore (1 5/8") pipes. Contact if interested. |
Re: Rover 4.6 long block for sale.....RV8 headers also.
have a set of the 1 1/2" RV8 headers with down pipes...ceramic coated. New..never installed. $750.00 plus shipping.
Hi, Tom,
Do you know if your 4.6 Rover long block can accept - easily - a 3.9 crankshaft ? I may be allowed to build up a 3.9 Rover engine for my SCCA GT2 MG RV8. I'm waiting for an answer from the Competition Racing Board of the SCCA on my petition to be allowed the use of the 3.9 Rover engine instead of the now required 3.5 size engine. And how much will you need for the 4.6 long block ? keep them on the track, phillip g |
rkas3882 randy kassed (84 posts) Registered: 05/30/2010 09:14AM Main British Car: 1973 mgb gt rover 3.5 |
Phillip, the 4.6 block has larger main bearings for the crank than the 3.5 and 3.9 engines. This change was made starting with the 4.0 blocks.
Phillip,
If you want to use the big bearing block with the small bearing crank. You can have it align bored for the smaller bearings by using the big bearings as spacers. File locating notches in your new "spacers" check for oil hole alignment and you're good to go. Cheers Fred |
BriansMGBV8 Brian Macmillan Seattle (61 posts) Registered: 09/26/2008 12:39PM Main British Car: 72 MGB Roadster Rover 4L |
Are the headers still available and if so whose was the manufacturer?
Thanks |
