Re: Schiefer Buick 300 Aluminium Flywheel
I could be wrong but that looks like a flex plate for an automatic trans. I've never see a flywheel like that. If I'm right, you might want to repost correctly.
Thats just the backside (or crankshaft side) of the flywheel Tim.
The screwholes that are visible are to retain the friction surface on the face of the flywheel. The allen bolts and the double splines visible in the center would lead me to believe that this has a dual disc clutch attached to it. I may also be wrong but there are no living witnesses to any past errors. Cheers Fred |
Now why didn't I think of that?
A good, low inertia setup. Leave it to Wotland Wotland to come up with that. He seems to find the best cast-off parts. Jim |
Wow, that's some knowledge bank you've got there in your Braunschweiger. I couldn't figure out that spline pattern. Wonder what that weighs and if it would worth finding all the clutch parts to fit?
Tim |
Dimitri, Are you also selling the clutch assemby ? You have counted the disk ? Spline dimensions are ? Cheers, roverman.
Art, yes clutch assembly is also for sale.
Specs : 3 discs 7.25" 28 splines. Ring seems to be in magnesium ( very very light). Bolt patteren is for Buick 300 crank. |
*Sigh*
$250 for the flywheel WITH the clutch and pressure plates attached? ( You're going to make me buy this damn thing, aren't you? ) |
PM sent.
i thought i was buying it, but i still haven't heard back from Wotland on my PM to him.
