Black P-38 Mike Caldwell Kentucky (51 posts) Registered: 09/18/2008 12:56AM Main British Car: None Squirrel Cage & 2 Squirrel |
Rover 4.0/4.6 damper with 36-1 trigger wheel attached, VRS, Coils etc for MegaSquirt
Thinking about running MegaSquirt on your Rover??? I'm selling my Damper/serp drive pulley with attached 36-1 trigger wheel, custom machined billet aluminum one piece plug to seal the cam position sensor opening in the timing cover, VR sensor, (new), VRS mounting bracket, EDIS-8 ignition module, (new), like new EDIS coil packs mounted to modified factory Rover coil pack bracket and the connectors with pigtails to wire up the module, VR sensor, coils with condensors and spout connectors.
The 36-1 trigger wheel is mounted to the rear of the damper via a custom machined brass hub adapter to keep it concentric. I'll take $160 for all including FREE Priority Mail shipping. Quickest way to reach me is my cel: 541-808-1182 THANKS! Mike |
Re: Rover 4.0/4.6 damper with 36-1 trigger wheel attached, VRS, Coils etc for MegaSquirt
The EDIS-8 ignition module has been sold!!!
The remaining pieces are still available for only $99!!! That includes the Damper/serp drive pulley with attached 36-1 trigger wheel, custom machined billet aluminum one piece plug to seal the cam position sensor opening in the timing cover, VR sensor, (new), VRS mounting bracket, like new EDIS coil packs mounted to modified factory Rover coil pack bracket PLUS the connectors with pigtails to wire up the module, VR sensor, coils with condensors and spout connectors. $99 INCLUDES FREE SHIPPING!!! Thanks, Mike 541-808-1182 |
Guys, this is a great deal, especially if you sell your stock damper which should easily pay half of this cost... plus the machining work is already done on the backside of the damper, the custom brass concentric adapter and good luck finding this particular 36-1 trigger wheel at an affordable price... it just happens to be the perfect size for this application. Also, mounting it BEHIND the damper keeps things compact and avoids the wiring having to cross the "belt path" as with front mounted trigger wheels.
Mike |
PRICE REDUCED TO $85.00, Shipped FREE via Priority Mail (U.S. only).
Mike |
The remaining items have been SOLD!!!
THANK YOU!!! Mike |
Dang, I got check this section more often - would have bought the LOT.
