Richard/SIA
Richard Brengman
No. Nevada
(401 posts)
01/17/2014 07:47PM
WTB Buick 225 head gaskets.
Posted by: Richard/SIA
Date: June 14, 2014 01:42AM
Bought the only parts readily available from Fel-Pro, then returned them as they are truly too large around the cylinder.
Seems they are trying to say they fit ALL the Buick v6's, not really true for a performance engine.
TA Performance no longer has any, and their source for the steel .030 steel shim gaskets stopped making them too.
There were a LOT of these engines sold so someone should have a set on the shelf, I won't mind a dusty package.
My old gasket measures .040 after crush, and 3.84" across the sealing surface from top to bottom.
My cylinder bore measures about 3.784".
I want to avoid a gap around the cylinder where the head gasket does not fully fill in as I understand it to make an engine prone to detonation.
The new Fel-Pro were over 4.0".
PM here or email to sia@pyramid.net
Richard/SIA
Richard Brengman
No. Nevada
(401 posts)
01/17/2014 07:47PM
Re: WTB Buick 225 head gaskets.
Date: June 14, 2014 03:41AM
UPDATE, Found a part number on the old gasket but had no luck with a web search.
Old gasket number is 6755 or e6755.
88v8
Ivor Duarte
Gloucestershire UK
(1042 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: June 14, 2014 04:12AM
Well, I suppose you've tried here?
[www.cleggengine.com]
and here
[www.northernautoparts.com] Gasket Set
Trouble with t'interweb, it's becoming a graveyard of useterwos.
Ivor
Richard/SIA
Richard Brengman
No. Nevada
(401 posts)
01/17/2014 07:47PM
Date: June 15, 2014 02:54AM
I will check those out on Monday.
Need to KNOW the inside dimension as most sources just push the oversize Fel-Pro gaskets.
Wish I could determine the brand of the old ones.
Date: June 16, 2014 11:30AM
Richard, I would try "Egge", in Ca. "Buick Farm", back east, ofr"Hemmings". Most V6's had a 3.800" bore. Cometic is pricey-but, you get what you pay for... roverman.
Richard/SIA
Richard Brengman
No. Nevada
(401 posts)
01/17/2014 07:47PM
Date: June 16, 2014 11:58AM
Bought NOS GM gaskets from these guys.
[www.collectorsautosupply.com]
They are a great source for individual gaskets and original gaskets for older cars.
I hope they will be correct, will send them back if they are also oversize.
They also list a .015 steel gasket but cannot confirm the cylinder bore dimension.
Todd McCreary
Todd McCreary
(207 posts)
03/16/2012 10:57PM
Posted by: Todd McCreary
Date: June 21, 2014 12:40AM
you could try Antique Auto Supply:
[www.youtube.com]
Richard/SIA
Richard Brengman
No. Nevada
(401 posts)
01/17/2014 07:47PM
Date: June 21, 2014 08:21PM
Once I know where to get the ones I want I will probably buy extra,
Best way to ensure I will never need them!
Richard/SIA
Richard Brengman
No. Nevada
(401 posts)
01/17/2014 07:47PM
Date: July 15, 2014 02:56PM
OK, the new 225 head gaskets finally arrived.
Original Buick embossed steel # 1357869
Steel is .025" thick.
They are embossed so I'm not certain of compressed thickness.
The old composite gaskets were .040".
Got them from www.collectorsautosupply.com
In the "Old days" we used to paint gaskets with silver paint before install.
Been a while, have we got a better system now?
STEEL gaskets.
