Richard/SIA Richard Brengman No. Nevada (399 posts) Registered: 01/17/2014 07:47PM Main British Car: 1969 Triumph GT6+ 225" Buick V6 |
WTB cheap or damaged Buick V6 single plane manifold.
Looking for a CHEAP Buick V6 single plane manifold for experimental purposes.
Can be cracked, missing mounting tabs, corroded, etc. Want to mill the top off so I can study possible modifications to fit IDF's. If it looks feasible I will then go after a good base. And some IDF 40's. |
Re: WTB cheap or damaged Buick V6 single plane manifold.
Since you're going to slice n' dice-anyway, why not an Offy/215 SP 4bbl or 2 x2bbl ?
Took a preliminary look.
Not much room atop the V6 manifolds. Need to find a version with a seperate thermostat housing. What's really needed is a more compact carb than the IDF. Trying to avoid a scratch built IR manifold. |
