hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
WANTED... D&D Ribbed pulley setup for Olds 215
Posted by: hoffbug
Date: December 25, 2014 11:58PM
Longshot of all longshots..
Im looking for the aluminum ribbed pulley set that D&D USED to sell. Long story short they arent currently making any more and they are out of stock.. Got a set you'd like to sell? Let me know.. Aftre years of collecting parts my Pontiac Astre with Olds 215 project is moving along...
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Re: WANTED... D&D Ribbed pulley setup for Olds 215
Posted by: hoffbug
Date: May 24, 2015 12:34PM
still looking.
Date: May 25, 2015 01:43PM
Tony, Have you considered the "late" oem Buick V6 serpentine parts ? Your results "may" vary... Cheers, roverman.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: June 08, 2015 10:21AM
Art.. Ive looked into that.. The problem I run into is that the water pumps on a true serpentine setup are reverse flow and the pulleys are driven by the backside (non ribbed side) of the belt.. I need a ribbed pulley there as I just want to run a ribbed belt like a standard and use the alternator to tension. I have yet to look into whether a Chevy or other pulley would work on a Buick water pump.
(6469 posts)
Date: June 08, 2015 12:01PM
Pulleys are not hard to make if you have access to a lathe...
Date: June 10, 2015 02:50PM
2 out of 3, ain't bad. OK buy oem on all but water pump. Make (1) pulley or adapt from Chev/etc. ?
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: June 12, 2015 03:27AM
Im going to check and see how a pulley from a "long" SBC water pump compares to a Buick 300 water pump pulley.. Im guessing they are both about 2".. If the holes line up I might be in business.. If I figure all of this out Ill post what worked.
Engine assembly is in progress finally.. Just the Olds 215 to start with... Since the car really isnt British I havent posted much about it here.. But you can look at some of the progress by clicking the link below.
[www.bangshift.com]
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: June 14, 2015 07:39PM
I went and looked through all options that would work with my swap and the only combination i came up with that could possibly work would spin the pump at 133% of crankshaft speed.. ( stock Buick 300 is 85%).. The Aluminum V-8 in a Vega is a tight swap from the pump to the radiator. so stock Buick V-6 stuff wont work...
I could machine those old March pulley as mentioned above but will that much increase in water pump speed be an issue/ There wont be a fan mounted so i wouldnt have to worry about blades flying loose..
(6469 posts)
Date: June 15, 2015 10:48AM
Tony, it really depends on whether you plan to run it up to redline or operate at high rpm for extended periods. If not, I wouldn't worry about it.
