Rotisserie
Now that the car is about to come back from paint, I'm making some room in the garage. Don't know if anyone in the Houston are needs a Rotisserie, but if so, this one will go for approx cost of materials. It's at the body shop right now & they're going to send me some better pics; for now, these are the best pics I have... Price is $100 (industrial casters & worm drive were about 1/2 of that) and needs to be someone who can pick them up. Way to heavy & bulky to ship.
Car on the rotisserie: This one shows how the back connects -- the horizontal bar bolts to the bumper bolt holes & the pipe goes into a larger pipe on the rear upright (not in this pic) This shows the front. Original pinch bolt design didn't work well so I modifed to use a winch worm drive. This pic was an in progress pic during the mod. The parts in the background are what connect to the front of the rotisserie & front of the car. IT bolts on to the captive nuts in the bottom of the frame rails & there are about 5 or 6 holes spaced an inch or so apart to adjust up/down to get a reasonable balance. |
Re: Rotisserie
Re: Rotisserie
Boy, I sure wished Texas were a whole lot closer to Vermont. The rotisserie would be sorely appreciated.
Re: Rotisserie
Yeah, they definitely come in handy. Way easier to do dog leg, sill, etc. repairs as well as do modifications &/or prep for paint on the rotisserie. This one is gone though. I also had it posted on the MGBE site & someone there grabbed it pretty quickly.
Engine stand is still available if anyone wants it. |
Re: Rotisserie
Hi,
I just built a rotisserie almost the same but I just ued two engine stand like yours. I cut some angle iron welded it to the round pipe and use the old engine hoist to lift it in place. 2 hrs. and presto, $ 100.00 max. But what is that rear end under your MGB? I am converting MGA to Rover V-8 and thinking Miata? rear. Thanks Steve |
Re: Rotisserie
Art - sorry, i should have updated this -- the rotisserie sold a long time ago to a guy in Louisiana.
Steve - the rear end is a custom IRS based on a Nissan R200S differential. |
Re: Rotisserie
Rob,
about the IRS rear end. Are you planning to install it on the MGB? If so, what mods have you done. I am not familiar with the Nissan R200S. Is this rear end up to take 200 HP ? I am looking at the IRS from a Miata. Anyone done this ? It would make the rear end about 5 inches wider. My rotissery is also made from 2 engine stands. Any input on replacing door sills and dog legs as I understand you must have done that on your "B". Werner |
Re: Rotisserie
Werner - it'd probably be better to post in the MG section of the board; you'll get replies form more people... but, in answer to your questions...
IRS - yes, it's in my MGB. Nissan R200S is a common Nissan differential used in a lot of their cars -- example is the 240SX. The 200 is the ring gear size in milimeters; it's just shy of 8" which is plenty for 200hp. I just ran my car on the dyno & had 255hp & 287 ft/lbs of torque at the wheels. I vaguely recall hearing about someone swapping miata running gear into an MG -- do a search using the "google" search box above... it searches the forum. I didn't have to replace the sills on my car. Best place to get info on that is by searching the MG Experience board. Lots of info & pics there. |
