MGB V8 performance parts for sale
have several parts that would be applicable to larger displacement Buick/Rover engines.
1. Harcourt intake with 4 Weber 40 IDA carbs. This intake is quite rare. Would need to fabricate a thermostat housing and also linkage, etc. This is NOS....never installed. $2000.00 2. Edelbrock intake 2X2 with adapters to work with the Weber IDA carbs. Has not been installed. $400.00 3. Bellhousing custom fabricated from 3/16" steel. Flange is 1/4". This is a work of art...was fabed for a race car but never finished. Is drilled and tapped for the Borg Warner (GM) T5. It is set up with the pivot pin for the clutch fork. Holes for mounting to the engine block need to be drilled in flange. $400.00. These parts are located in SE Michigan. PM for photos and more info. |
Re: MGB V8 performance parts for sale
quote: Bellhousing custom fabricated from 3/16" steel. Flange is 1/4". This is a work of art...
Don't tease us like that! Would really like to see photos here in the thread. |
