Wanted - Buick or olds 215 harmonic balancer and A/C install
Guys
I am looking for a Buick 215 harmonic balancer. I am putting A/C on my MGB V8 (Wife's Request for continued participation) and need the GM 215 version harmonic balancer with pulleys if possible. I have a Rover P6 3500 motor in my 1979 MGB with the Clive Wheatley conversion parts and a std. MGB V8 radiator. The alternator is mounted on the passenger side using the Clive Wheatley cast aluminum mount. Any suggestions on how to do the install would be appreciated along with A/C kit recommendations good or bad for the cockpit and condenser setup. Contact RVrana@vrana.us Edited 1 time(s). Last edit at 11/21/2017 06:03PM by MGBV8. |
Re: Buick or olds 215 harmonic balancer and A/C install
You might try D&D for a used Buick harmonic balancer.
[www.aluminumv8.com] ........and for front accessory drive ideas w/AC compressor, have a look at the Brit V8 photo galleries/'How it was done' archive for examples. Here’s Rick Ingram’s HIWD, for example...... [www.britishv8.org] |
t-100 Glenn Towery (31 posts) Registered: 09/09/2009 10:55PM Main British Car: 1974 1/2 MGBGT 3.9 Rover V8 |
Been there done A/C in a MGV8 for over 20 years now! I have the 2 grove H/B to go on the Rover engine. My compressor mts. on the drivers side. Would be best to give me a call for more info & parts. Thanks Glenn 302 734 1243
Edited 1 time(s). Last edit at 06/24/2020 08:10PM by MGBV8. |
