reblacklaf Randall Black Rensselaer, IN (8 posts) Registered: 05/24/2011 12:35PM Main British Car: 1969 Opel GT hotrod Buick 215 bored/stroked 302cu |
Weber Manifold wanted with carbs
I am looking for one of the following used setups:
1. crossram Weber sidedraft setup with carbs and linkage 2. downdraft weber setup with carbs and linkage 3. Very rare Mickey Thompson dual quad manifold carbs and linkage not needed I have a modified 215: bore/stroked to 302 cu, 300 crank, rover callaway heads, TA Performance Rover roller rockers, solid lifter Crowler cam, 12.25 to 1 compression with a 2x2G manifold. I currently run out of carb before I run out of cam. Randy (OldeBuick) |
Re: Weber Manifold wanted with carbs
You've seen John Eales' offerings?
[johnealesroverv8.co.uk] New, rather than used. I expect he could help you with carbs. Ivor |
