Zack_008 Zack Zimmerman Portland Or (21 posts) Registered: 06/29/2019 03:12PM Main British Car: 1931 Ford Buick 215=>281 |
Buick oldsmobile 215 heads, rocker shafts, 4bl intakes
Bunch of heads to be considered cores. Total of 9 Buick heads with one needing a lot of work due to corrosion around the intake water jacket. Total of 2 oldsmobile. I do have a second set on a motor yet to be disassembled if there's a curious party. If the chamber size can be determined by the casting, I can get that.
$20+ride for the corroded one $60/ea or $100 set +ride for the buck heads $80/ea or $100 set +ride for olds Total of 9 rocker shaft assemblies. 5 have "Buick " stamped into at least one rocker. Two have no brand visible. One has a broken rocker tip. One has the wrong rocker in the set of intake/ehaust. $40/ea or $60 +ride per set One set of Buick heads and 4 bbl that are ported to match. Due to the 6 image limit im just including the intake port comparison to the stock 215. Said intake has been cleaned since pic. Heads are glass blasted. $300 +ride One 4bl intake that had been opened up into a single plane. $100 +ride All located in Portland Oregon 97233. Zack five0three . Three2zero . 2 five 98 Also have a couple timing covers, cranks, 300 cranks that need work, core distributors, valve covers, bare blocks, 1 complete Buick, 2 olds, |
Re: Buick oldsmobile 215 heads, rocker shafts, 4bl intakes
Prices are negotiable. Will be at the Good Guys in Puyallup next weekend if there's anyone in the Seattle area that's interested.
