Zack_008 Zack Zimmerman Portland Or (21 posts) Registered: 06/29/2019 03:12PM Main British Car: 1931 Ford Buick 215=>281 |
SOLD! --- Buick 300 aluminum heads and intake
Buick 300 aluminum heads. Look to be mismatched. Casting numbers are CFD1358219 12PM and the other 19PM. One head would need some attention around 2 of the exhaust ports from corrosion. Both should be worked around the dog bone water jackets. Nothing crazy, just typical old aluminum Buick heads. Intake has both water neck bolts broke and one breather bolt broke in it.
Looking for 600+ ride for the set. I have other 215 stuff, heads blocks, timing covers, cranks, looking for something? Ask me. Zack Located in 97233 Edited 2 time(s). Last edit at 09/30/2019 01:51AM by Moderator. |
Re: Buick 300 aluminum heads and intake
That's a deal. Somebody ought to jump on that.
Willing to split if someone just wants the heads. I know the deck height from the rover/215 is different from the 300 so it is application specific.
I've seen those intakes go for as much as $400 and the same for a set of heads. I know for many of us it seems like a lot but it's the only 4bbl intake you can get for that motor. You can find them for less sometimes but the last one I bought had to have a heliarc repair. So I think the price is pretty fair and then there's the scarcity. Not available quite as often as they used to be. Thinking about it? Coudn't hurt to make an offer.
" it's the only 4bbl intake you can get for that motor."
Only aluminum one. The only other year for 4 bbl was 1965 & it was cast iron. |
I just picked up a 300 so I'm keeping the intake.
Heads are still available. $350 + ride for the heads. |
