dvanzuiden Dave VanZuiden Dane WI (5 posts) Registered: 03/01/2016 09:38PM Main British Car: 1973 MGB 1963 Buick 215 |
Buick 215 V8 T5 Trans Bellhousing Supercharger
Hi,
I have a number parts I'm looking to sell. Just got into this project about 5-6 years ago, and now really just dont have time to make any progress. I have a collection of buick v8 215 parts. There is a complete engine that doesnt turn (or at least I havent tried over the last 3 years. I bought it, put some ATF in the cylinders to see if it would free up, but havent ever tried real hard to turn it over). I also have a cleaned block that will likely need the cylinders honed. There are a number of engine parts all out of the cleaned block. There are really only 6 decent pistons in the bunch. The cylinder heads are rough, but could probably be cleaned up and rebuilt, however 1 does have a broken valve. I have an original clutch and a newer clutch for the engine. A McLeod hydraulic throwout bearing. This will likely need to be sent back to McLeod to be rebuilt. Additionally I have a T5 Transmission (I believe out of Camaro). This appears to be in good working order. I have a driveshaft to go from the T5 to a stock MGB rear end. The supercharger is off a buick 3800. Appears to be in good working order. I would like to get the following: Engines (both and all the parts minus the bellhousing, supercharger, driveshaft, trans, new clutch): $500 Transmission, Bellhousing, driveshaft, new clutch, throwout bearing: $750 Supercharger: $125 Or come take everything for $1,200 I also have a 1973 MGB, that I will likely part out as there is just too much rust on it (floors, sills, and enough other bits), if you're interested (original 1800 engine and trans are already gone). I paid $750 for the car, but that was probably too much... Located Just outside Madison Wisconsin. Thanks, Dave |
Re: Buick 215 V8 T5 Trans Bellhousing Supercharger
I'd be interested in just the bellhousing, shipped to zip code 20180.
MSDMGBV8 Michael Domanowski Delaware Counties New York (12 posts) Registered: 05/20/2008 12:04PM Main British Car: 1978 MGB V8 Oldsmobile 215 stroked to 277 ci with Nitrous |
Is the bellhousing still available? if so how much for just that?
