rebuilt Rover 3.9 with Rover 5 speed
Have a Rover 3.9 engine that was rebuilt several years ago, but never started. It is a complete long block (std mains, rods and bore) with cam, lifters, push rods, rocker assemblies, Rover valve covers, timing chain, timing cover, harmonic balancer, oil pump and cover and Rover oil pan. Also has lightened flywheel, clutch assembly, clutch fork and throw out bearing. Rover (TR8) bellhousing, Rover SD1 5 speed with new oil pump and shortened shifter housing to fit the MGB shifter location. Does not have intake and carb, but can furnish if desired. Engine does turn over but since it has been sitting for some time would recommend it be taken apart and checked. Can load on pallet for shipping via truck. $3000.00 OBO. mgbv8542@yahoo.com
