Cheapsnake Tom Soik Door County, WI (10 posts) Registered: 02/17/2009 08:43PM Main British Car: '80 TR8, Factory Five Cobra, Porsche 914/Rover V8 Rover 3.5/4.0 |
FS: Buick 215 Dizzy, rebuilt, Rover (BOP 215?) timing cover, pulleys
Cleaning out the shop:
Buick 215/Rover distributor, rebuilt with new vacuum advance, new cap, Accel points eliminator and new wires. Used for about 5 minutes for a couple bench starts before I decided to go with an EDIS (distributorless) ignition system due to space limitations. $100 Timing cover/water pump off a Rover 4.0. Bought it used, never installed so can't confirm condition but it's clean and sure looks good. $75 Rover/BOP 215 valve covers, the stock stamped steel ones, all cleaned up and painted. $25 Other stuff: (2) new valley pan gaskets, one of them in an original Buick OEM package. There's only one of the rubber end seals between them. $25 each, both for $45. (1) set of composite head gaskets. $30 (1) set of cork valve cover gaskets. $15 (2) crank pulleys, one fits inside the other and bolt into the HB. I'm really not sure what they're supposed to drive, bought them with a project engine and never needed them. Clean and painted black. $10 All prices are + shipping. email me at ffr2776@sbcglobal.net for more info. Tom |
