1967 MGB GT V8 Ready (Great Project Car)
Up for Sale is a 1967 MGB-GT thats been set up for a v8. The car comes with no engine nor trans, but is set up to just drop a v8 and tranny. Therefore the cutting, boxing and mounting supports are already for a new engine and transmission.
Few items of interest that come with the car are the following; Aluminum hood, Fiberglass fenders, Gabriel Shock suspension kits set-up on all for tires (Note the front suspension set up and bracket on this car.) and Shorten Chevy possi rear end with 243 gears with drive shaft to tranny. This car would make a great v8 daily driver or great track car. This is a project car with hours of modification work already done to fit a v8. Additional information is listed below. Only serious inquires and no tire kickers PLEASE! Only asking $1,500...Pictures available upon request. Contact: rommel_mejia2002@yahoo.com Car located in Raleigh, NC Engine compartment set up: Has no engine nor transmission Car is set up to fit a small block Ford or Chevy engine Car had a small block ford with a C4 transmission Fire wall cut to fit v8 and engine will set back further then original 4 cyc. Shorten possi Chevy rear end with 243 gears w/drive shaft. External oil set up Exhaust in place Frame set-up: Re-built front end with some chromed parts. Steering rack adjusted to fit a v8 Gabriel Shocks and brackets set up on front and rear end Front shock brackets are made by Wheelwright. Newer leaf springs Body parts: Fiberglass fenders Aluminum hood New windshield with gasket New quarter panels welded in. Frame rails, rocker panels and floor panels are either replace or in great shape. Very solid car. Doors are rough, therefore might be easier to replace with new/used parts. Sun roof on top Interior: Dash in good shape Smith tachometer set up for v8 Rebuilt oil & gas gauges (smith) Need carpet, seat work (new seats) and some trim |
