Wanted: Oil filter base (angled)
The 215 has a small straight casting that forms the bottom of the oil pump and gives a spot for the oil filter to screw on to. I need the same part only made to angle forward somewhat. I believe this would be the one used on the Buick V6 and the other Buick small blocks and a similar one may have been used on the Rover as well. Please reply if you have one you would part with or have info about what one might be appropriate. Thanks,
JB |
