Wanted : P76 block and Buick Stage II V6 parts
Hi, On the P76 block, bore/sleeves,not important. No cracked or worn out aluminum bores., no thrown rods. Need a Stage II,"on center"/ siamese bore block, gear drive and crank trigger ign., for same. Thanks, roverman.
Re: Wanted : P76 block and Buick Stage II V6 parts
Greg and clan, Before I considered "all" of the benefits of the late rover blocks, I was thinking the P76 for a 340/350 crank, possibly with TA heads. Stage II "on center" block is for a transverse, mid engine build. Cheers, roverman.
Yes Greg, might I suggest to share on this forum ? Good Luck, roverman.
