FS: Sprite Midget competition parts: suspension, tiers & wheels
I have a lot of Sprite & Midget performance suspension stuff that I no longer need. Most of these parts were new, when mounted on my car... but never driven.
Front end: Tube-shock conversion kit, KYB shocks, 3/4" A-sway bar, with poly bushings mounts, refurb'ed A-arms w/ poly bushings, timken roller bearings, 400 pound springs, Big Brake upgrade kit (Mini-mania adapters, TR rotors & MGB calipers). $500. Rear end: Narrowed Mazda RX7 LSD, professionally re-shimmed LSD w/ 411 gears, 1/4 elipt springs (3 leaves removed), used Koni adjustable shocks, panhard rod, disc brakes. $750. I also have a set (4) of un-mounted RWA flares and airdam. $200. 14" Ultra wheels (4 on 100mm) w/ Kumho Ecsta V700 competition tires, zero miles. $400. C&R racing radiator assembly and mount: aluminum, crossflow, 1000CFM electric fan, remote oil filter mount and cooler. $250. Pontiac Fiero seats, no speakers, driver side shows wear. I can send photos of any of these and I prefer not to ship. located in the south San Francisco bayarea. Thanks, -Drew 925-225-4714 agriffith-at-litrex.com (or use the British V8 message board's "private message" system.) Edited 1 time(s). Last edit at 04/29/2008 11:04AM by Moderator. |
