crashbash
david bash
st. charles
(193 posts)
01/28/2008 10:53AM
1979 MGB Rdst V8 project, 1968 MGC GT, 1969 MGB Rd olds 215
v8 MG valve covers
Posted by: crashbash
Date: March 08, 2012 05:51PM
Does anyone know where I can find a set of MG logo valve covers? Olds 215 with Buick 300 heads. Roller rockers
(2288 posts)
Re: v8 MG valve covers, roller rockers ?
Date: March 09, 2012 02:32PM
David, If you mean oem., as in MGB GT V8, I suspect they will NOT clear roller rockers. Might be better to use taller after market, and add logo ? What does" Yella Terra" say ? Good Luck, roverman.
crashbash
david bash
st. charles
(193 posts)
01/28/2008 10:53AM
Date: March 09, 2012 04:10PM
Thanks Art
Thought about that and will have spacers cut by semi Local with a new waterjet toy. He has fabed the rover/bop head boring plate and it's a beauty. I like the finned MG logo. Venting? Tall rover valve covers look like they would work?
(3486 posts)
Date: March 09, 2012 05:46PM
Carl has the MG covers. He's been having an issue with blowby pressurizing the seals. IIRC there is just 1 threaded port in each valve cover, 1/4" I believe. Certainly not big enough to properly vent the engine, even the old road tubes were at least a 1" diameter but usually larger, so they can only handle something like 1/16th of the flow at the same pressure. Meaning of course that you'll need to increase the venting somehow. I think there is a second boss on each cover but a better choice is probably to use the fuel pump block off plate for a 3/4" vent line.
