Wanted: Land Rover Heads, Oil Pan & Other 215 v8 Engine stuff
Looking for:
1) Land Rover Heads on a 215 V8. ERC 0216 or HRC 2210. 2) Oil pan for same engine or for a Buick 215 V8 3.5L. 3) Oil pick up for applications above. 4) Also looking for new cam, pistons (probabably +30, 10.25:1 compression), and valve springs. |
Re: Wanted: Land Rover Heads, Oil Pan & Other 215 v8 Engine stuff
Recommend you use the V6 pickup which is 5/8" diameter. Drill the block to match.
You should contact Jim Stuart (personal message), he has some of that stuff and also Ed Chin has some Rover parts.
