restorejag Mike Alexander Richmond Va. (24 posts) Registered: 02/19/2008 05:53PM Main British Car: 1974 MGBGT 1958 MGA 1968 JAG XKE Ford 302 215 OLDS |
Rover 4.0 for sale
Complete rebuilt Sept 2012., Heads resurfaced, valve job,new rocker shafts,positive seals intake and
exhaust. Crank was polished,did not need grinding,cylinders honed. New rings rod and main bearings. Roller chain and gears.high capacity oil pump,Crower cam and lifters,new head studs ,water pump,short shaft, freeze plugs.distributor rebuilt Igniter kit,high output coil. I converted to carb,intake,timing cover , oil pan from Buick 215,new Elderbrock 500cfm.I have the EFI parts. New flywheel for Ford or GM clutch,Motor will except Ford or GM T5 transmission,crank is still long. The motor comes comlete as pictured except test stand. I built the motor for my MGBGT but have changed my mind ,using 302. I all ready have two bop MGB. Price is $3,500 plus shipping. Located in Richmond Va. 804-212-4060 Mike |
Re: Rover 4.0 for sale
Sold
