Frame is from a 1970 TR6. Set up for Chevy small block drivetrain. All mounts and engine placement have been completed. The frame has a custom, asphalt modified inspired front suspension featuring tubular upper and lower Troyer control arms, 1978 camaro spindles and brake setup, stock TR6 rack with Goodparts aluminum rack mounts, custom made reinforced shock towers with AFCO small body coil overs. Front suspension is fully adjustable. The rear suspension has been converted to an S10 solid axle with custom made TR4A leaf springs. Frame comes with C3 corvette aluminum wheels. There are hundreds of hours and thousands of dollars spent on this frame. There is too much to list here but I can tell you all about it. I'm asking $2500 or best offer. Call (732) 473-9682 or PM me here.
