Buick 215 short block...rebuilt.....also heads
have a 215 short block that I got in a lot purchase. It appears to be rebuilt..block is clean and has been decked.
It has .060 pistons and I pulled off a main cap and rod cap and the bearings are .010. If you purchase I would suggest to go through and double check everything.. $750.00. Also a set of Buick 215 cylinder heads that appear to have been rebuilt. Have been cleaned and surface machined. New valves & springs. $400.00 for both. Can load on a pallet for shipment. PM with questions. |
