Volvo 940 distributors (2)
Date: June 30, 2014 01:43PM
I need excellent used, or new. This be for my 32 valve RV8 project. Thanks, roverman.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Re: Volvo 940 distributors (2)
Posted by: ex-tyke
Date: June 30, 2014 06:45PM
No doubt you've checked Car-part website - some available in California.
[www.car-part.com]
ex-tyke
Graham Creswick
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: June 30, 2014 06:48PM
Hmmm......'website issue...try this:
[www.car-part.com]
Date: June 30, 2014 07:18PM
Looks like remanufactured 940 distributors go for about $154 (including core charge) on RockAuto, plus you'd need to buy rotors and caps separately. Ref: [www.rockauto.com]
Date: July 01, 2014 10:56AM
Perhaps I'm cheap, $154. for "Cardone" rebuilt, with no vacum or centrifugal advance, so they clean it and "maybe" replace a bushing ? I would like to find a short/side wire, with centrifugal. Thanks all, roverman.
Date: July 01, 2014 03:54PM
I know you're concerned about appearances... but have you considered making fake distributors (or fake magnetos!), and actually having crank-fired electronic ignition and multiply coils squirreled away? It could be so much more precise and also more easily tunable. It's not like the Volvo distributors are all that handsome.
Date: July 02, 2014 11:56AM
"fake distributors", where do I hide the crank trigger ? I actually like the Volvo cap. Maybe I should make custom bodies, to fit these caps ? As for "precise", I could re-time ,if cams are indexed +/-. I wish a Volvo guru, would chime-in here... Fred ? Cheers, roverman.
Date: July 02, 2014 12:40PM
Mount a toothed wheel to the back side of your flywheel.
Here's where Rover put their crank position sensor on later model engines:
http://www.landroverclub.net/Club/Disco_new/Crankshaft%20position%20sensor.jpg
Or, if you prefer, I'm sure you can find suitable Hall effect sensors to mount through your bellhousing or on a bracket inside your bellhousing.
Distributors driven off cams are always subject to timing chain bounce or gear lash. Mechanical advance mechanisms are crude too, and to tune them properly you need a distributor dyno. Weld here, grind there, try different spring combinations... and then do it all again on distributor number two. Tuning ignition advance with a laptop while your car is on a rolling road is just better all around - and with electronic control you can even advance/retard individual cylinders.
For a very retro super-high-performance look... Vertex magneto caps!
http://www.britishracecar.com/ScottHughes-McLaren-M8F/ScottHughes-McLaren-M8F-BL.jpg
