narrowed ford 8" rear
I have a narrowed ford 8" rear end for sale. Built for a triumph tr4 vintage race car - I decided to go with the lighter stock unit and modify it (should work with a tr2-4a solid axle). Will also be about the right dimension for an mg. Moser axles set up as 4 x 4.5 bolt pattern. Has 3.73 gears and a mini spool. I also have a 3.55 ring & pinion set still in the box and the original 3.00 r&p $650 obo.
ex-tyke Graham Creswick Chatham, Ontario, Canada (1127 posts) Registered: 10/25/2007 11:17AM Main British Car: 1976 MGB Ford 302 |
Re: narrowed ford 8" rear
Axle width?.....spring pad spread/angle?.......brake groups?.....anything else which would help sell....oh, and don't forget some photos.
