ghornbostel Greg Hornbostel Nebraska (76 posts) Registered: 09/02/2013 01:41PM Main British Car: 1957 TR3 Buick 231 evenfire V6 |
TR3 speedometer
I need the return spring for a TR3 speedometer. A unit that is in not so good condition as long as the spring is there would be considered.
Re: TR3 speedometer
I;ve got some tr3 and tr4 speedometers I know for sure the 4 one is preety junky just good for parts.Would the springs be the same? I;ll check the 3 ones and see if one is bad enough to canaballize otherwise tr4
Re: TR3 speedometer
Hi Greg. I sent you amessage yesterday but I dont see it anywhere so I will do it again just in case. I found two unit without glass .one is a tach with a really good spring and needle and a speedo with a kind of sticky needle. I wd40d it and it is better but not perfect.Why dont I send both to you for twenty dollars plus the shipping? I'll find out how much to ship on Monday and let you know Tim ps I still have five or six good ones and won't miss these.
