Re: Need a 215 flywheel......
I have a shaved down flywheel that I got off a wrecking yard engine in the early 70's. I have no idea how to find one today. Good luck. (I was simply trying to follow the posts but could figure that out!)
MGBV8 Carl Floyd Kingsport, TN (4014 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB, Buick 215 |
Jegs or Summit will have a McCleod steel flywheel. Ted Schumacher will have a lighter steel one.
[www.tsimportedautomotive.com] |
BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (5984 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
I cut a D&D steel flywheel down to 20 lbs and think it could go lower, especially if you know a good guy with a waterjet machine.
Aluminum is the way to go though if you can afford one. Jim |
