hothealey54
Michael Brown
(10 posts)
10/12/2014 09:22AM
215 clutch flywheel and bellhousing
Posted by: hothealey54
Date: December 08, 2014 07:42PM
I was at the local Pull and save wrecking yard today and the is a Opel Manta with a stuck 215 buick with a clutch and 3 speed. If any one needs this i could go pull it. The intake is gone and the motor will not turn with the fan. I have only seen a few stick setups for a 215 I believe they are hard to come by.
(6590 posts)
Re: 215 clutch flywheel and bellhousing
Date: December 09, 2014 08:46AM
The 3 speed bellhousing is said to be different from the 4 speed (muncie pattern, T5), however Saginaw made a 3 speed that I'm pretty sure used the same pattern. There was at one time I believe, an adapter plate to go from the 3 speed bell to the 4 speed. It may be possible to redrill for the 4 speed pattern.
Someone should go get that, even if just for the flywheel.
(4629 posts)
Date: December 14, 2014 03:43PM
There were some bellhousing with both 3 & 4 speed pattern. Mine was this way & only the 3 speed holes were threaded. I had to run a tap into the 4 speed holes
hothealey54
Michael Brown
(10 posts)
10/12/2014 09:22AM
Date: December 15, 2014 08:24AM
The bellhousing looks to be standard chevy pattern. If any one needs it i will pull it for a small fee.
(6590 posts)
Date: December 15, 2014 10:21AM
You'd better pull it anyway. They'll probably only want $50 for it and it's worth twice that anyway. If the flywheel is flat that goes for it too.
(4629 posts)
Date: December 15, 2014 03:00PM
Dual pattern (3 & 4 speed) bellhousing.
[www.rickwrench.com]
Scofflaw Vicky
Todd Grebin
Southwest Virginia
(7 posts)
10/20/2014 09:28AM
1995 Disco and 1930 Model A 3.9 Rover and 215 Buick respectively
Posted by: Scofflaw Vicky
Date: December 26, 2014 11:06PM
Did you ever pull that bellhousing Michael? I would be interested in it probably. I have a GM T-5 that I would love to actually be able to connect to my 215.
