Get yourself a Rover Based OHC F1 engine AUD 16,000
Obviously, not mine.
Repco Brabham ( Australia ) is looking to sell some of their pieces, including 2 block and girdle combos. The blocks are 85mm and the crank is 72mm which i am calculating to be 199.43ci or 3.268L. It would seem to be a very oddball displacement. The current exchange rate is ~.81 USD to AUD, so you'd be looking at about $13,000. [repcobrabham.com] REPCO BRABHAM ENGINE PARTS Two 6 series 85mm bore Cylinder Blocks and steel stiffener plates (numberedE13A and E11B) 72mm stroke Laystall crank to suit above (crack tested OK) New fully machined 620 timing chest Re-conditioned oil pump Used oil pump (body only) Nine new ARGO conrods to suit 800 series short block Assorted un-machined castings Lucas camshsaft driven/electric fuel injection pump with clutch drive Bosch ZV8 twin point racing distributor with h/t leads One pair of steel camshaft blanks, $16,000 AUD o.n.o. the lot |
Richard/SIA Richard Brengman No. Nevada (400 posts) Registered: 01/17/2014 07:47PM Main British Car: 1969 Triumph GT6+ 225" Buick V6 |
Re: Get yourself a Rover Based OHC F1 engine AUD 16,000
There was a time I would have jumped on that.
Then built a car around the engines. Of course back then the price would have been a LOT less too. These are a long way from running engines. I expect they will go to someone running a vintage formula car. |
Kinda worthless without the DOHC heads...
*shrugs*
We've got guys looking at fabbing up DOHC heads. If you've already got a block designed for OHC cams, that might make your life a lot easier. Repco also has the historical curiosity thing going for them. |
I wondered if "Assorted un-machined castings" might include raw cylinder heads.
mgbman Marshall de Leon Salem, Oregon (54 posts) Registered: 01/15/2014 11:43PM Main British Car: Mark 2 Jaguar Chevrolet 350 |
I was about to shell out the required amount of cash and suddenly realized that Christmas was two weeks ago...rats, missed out by this much, Agent 99!!
