BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (6587 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
Re: Buick 300 intake 2 barrel or 4 barrel 1964
You can also use the BOPR intakes with a set of spacer plates and a sheet metal valley pan. That opens up a lot of possibilities.
had to buy it Lorne Mitchell Toronto, Ontario (20 posts) Registered: 11/04/2013 06:09PM Main British Car: |
I have 215 2 barrel manifold if that will do . Pic attached I hope.
Where would you get spacers? I have a 2 barrel Olds 215 intake. Spacers would make it work on a Buick 300 with Aluminum heads? I think carbs are limited on the 2 barrel 215 intake. I have big rochester 2barrels that would fit on a 300 intake. I also have a tiny rochester on the 215 intake
The Aussies have 'em. TRS or Dellow would be my first tries.
Dan Jones Dan Jones St. Louis, Missouri (311 posts) Registered: 07/21/2008 03:32PM Main British Car: 1980 Triumph TR8 3.5L Rover V8 |
Andy,
I've got a 1964 Buick 300 2 barrel aluminum intake manifold. IIRC, it is in very good shape but I'll check it tonight. Dan Jones |
Replied to your PM. I found a Buick 300 four barrel and a Buick 215 2 barrel. I have another storage area to search tomorrow.
Dan |
