Meziere Billet Electric Water Pump for BOP/Rover V8 & Buick V6
Presently on Ebay: [www.ebay.com]
$339.00 with FREE SHIPPING to the US NOS (NEW OLD STOCK). This billet pump was purchased by me in 2000 for a Jensen Healey V-8 project but NEVER USED. It is NEW and IN ITS ORIGINAL BOX which is dirty but intact. It was stored in my garage on a shelf and was NOT exposed to the elements. The contents of the box are PERFECT and PRISTINE. This pump frees up horsepower which is why I bought it for my Range Rover V-8 powered project but never used it. It is a high quality, American made performance/economy item. Jeg's discount price: $432.21 Applications: Buick V6 169-274ci 1961-1989 Buick V8 215-350ci 1961-1974 Jeep V6 255ci Oldsmobile V8 215ci 1961 & 1963 Range Rover 3.5-4.6L 1964-up From the manufacturer's website: "Electric water pump, fits small block / V6 Buick, 35GPM, standard motor, black Price: $475.43 Sku: WP125S Product Information Product Description WP125S - Electric Water Pump American made with quality far superior to any other performance aftermarket company, we build our water pumps with pride right here in the USA. Don't be mislead by inflated flow numbers and competitors' outlandish claims. We say what we mean and mean what we say. Our 2 year, unlimited mileage guarantee and full satisfaction money back guarantee should convince you that buying Meziere is buying value! This water pump model features: Fits small block Buick / V6 Buick Suitable for street or drag strip use – 2500+ hour life expectancy Show quality black anodized finish Standard motor provides 35 gallons per minute free flow rating All stainless steel hardware included Light weight. Complete standard small block Buick unit weighs only 7.0 pounds! Stainless steel large diameter main shaft with high performance ceramic seal 1" NPT inlet adapters are available for #12AN, #16AN, #20AN, 1¼", 1½" or 1¾" slip hose Technical Specifications: Finishing The System: This pump is supplied complete with gaskets and hardware but without the inlet fitting. The fitting needs to be ordered according to the size of the lower radiator hose. Amperage draw: Under normal use the pump will draw 6-7 amps. Overall Height Dimension: The standard pump is 6.80" long from the mounting surface to the tip of the pump. Pump Weight: This application weighs 7.0 lbs. 16 volt systems: When purchasing a pump for a 16 volt system we recommend the 16 volt optional motor on our pump. The 12 volt pump will work for limited use applications. Additional Notes: The standard 35 GPM pump is suitable for normally aspirated engines up to 650HP. Supercharged, turbocharged and high compression, high horsepower applications should use the 55GPM High Flow pump only. This model does not accept heater or bypass hoses as a standard." ******************************************* Please contact me with any questions and thanks for looking! |
Re: Meziere Billet Electric Water Pump for BOP/Rover V8 & Buick V6
Price reduction--$319 plus free shipping to US
Frees up a few ponies! Thanks, Russell |
SOLD ON EBAY!
