For Sale: Buick\Rover\TR8 Stuff
TR8 3.08 rear diff drum to drum - $300
TR8 instrument cluster (needs clear face cover) - $200 TR8/SD1 Federal Fuel Injection system with harness(NO computer) $250 TR8 drive shaft $100 Leyland P76 4-speed bellhousing - $225 (fabricated adapter plate required to work with Ford Mustang V6 T5 with long input shaft) Leyland P76 bare block - $200 Leyland P76 3.5" stroke crankshaft and flywheel (crank cut 10/10) $400 SD1 exhaust manifolds - $100 SD1 alternator bracket - $75 1964 Buick 300 aluminum intake 4 bbl - $200 1962 Buick 215 4 bbl intake - $100 D&D Vega 215 notched oil pan - $150 D&D Vega 215 crossmember mount brackets $150 Advance Adapters bellhousing to mate Toyota R154\jeep AX15 to Small block Chevy\BOP - $250 Advance Adapters plate to mate Toyota R154\jeep AX15 to Small block Ford bellhousing - $225 Novak Adapters plate to mate Toyota R154\jeep AX15 to Small block Chevy\BOP bellhousing - $225 Greg greg55_99@yahoo.com Sturbridge, MA |
