RDMG Dave R Northern Virginia (131 posts) Registered: 04/07/2016 08:29PM Main British Car: 1979 MGB 4.6L Rover V8 |
Wanted: Rover 4.6 water pump core
If anyone has these around, I'd like to hear from you.
I need to pressure test my block, and have no water pump at all. Would prefer to not buy a new one until I know the engine is good. Dave |
DiDueColpi Fred Key West coast - Canada (1267 posts) Registered: 05/14/2010 03:06AM Main British Car: What if the Hokey Pokey really is what it's all about? |
Re: Wanted: Rover 4.6 water pump core
No need for a water pump when you're doing a pressure test.
Just grab a piece of rigid material big enough to cover the water pump port into the block. You can use metal, plastic, fiber board or whatever else that is on hand. Drill a couple of holes in it to match the block, give it a skim of silicone sealer and bolt it on. The rover blocks are divorced side to side so you can test one side at at time. The same thing is done to the two ports on the block deck. One of the three "plates" will need a pressure port drilled into it to introduce pressurized air. Easy peazy. Cheers Fred |
contact PT Schram
PT scram Rover repair. 260-804-0458 Ask him to got out back and kick one out of the dirt :-) let em fat boy said so Afi |
