declan Declan Gardner St. Louis (62 posts) Registered: 05/12/2017 12:28PM Main British Car: 1969 MGB 1800 |
SOLD - Firebird rearend narrowed and mounts welded for MGB
80’s Firebird rear end, 5 lug(bolt pattern same as MGC 5 lug), disc brakes, limited slip, “3:3/1 I think”, and mounts to fit rubber bumper MGB (this may be the same as the chrome bumper?). The brakes will need a proportioning valve in line when you set up the new lines. $1200
Edited 1 time(s). Last edit at 10/30/2017 11:15AM by MGBV8. |
maxwedge5281 larry ingram (49 posts) Registered: 09/23/2014 05:59AM Main British Car: 59 bn6 zz4 sbc, 63 bj7 383sbc |
Re: Firebird rearend narrowed and mounts welded for MGB
w2hat is the width from bolt on to bolt on surface? i am looking for a narrowed rear for an austin healey 3000. thanks
Given the high cost of truck freight for this unit, I would offer $700 for it providing its length is 52" and it is around a 3.3 ratio. My reasoning is that I have been strongly considering a Quaife LSD installed in my MGC 3.07 axle which would cost me about the same once shipping is thrown in.
Not sure how I miss measured, my flat edge may have been on a stud. Wheel mating surface to wheel mating surface is 50.5".
3 and 1/4 turns of the driveshaft to turn the wheel. It is a 10 bolt rear end, I am going to try to identify whether it is a 8.2 or 8.5... |
$500
I am selling this to help offset the cost of sending a really nice b motor to a shop to be assembled so I can drop that in my car. Someone with a nice v6-or v8 project needs this more than I do. |
Still available. PM me if you need specific information, such as numbers stamped on the housing or need something measured, calculated...
