RDMG
Dave R
Northern Virginia
(138 posts)
04/07/2016 08:29PM
1979 MGB 4.6L Rover V8
WTB: one Buick 300 Aluminum Head
Posted by: RDMG
Date: September 20, 2018 04:47PM
I have a mismatched set, one in fine condition, the other heavily corroded.
Would like to know if I can buy a single head for less than the cost to weld up and rehab the dodgy one.
Surely someone out there has an orphan?
Re: WTB: one Buick 300 Aluminum Head
Date: October 31, 2018 04:25PM
FWIW. unless it's just at the "dogbones/ coolant transfer", at each end of head, don't waste your time/money. It's where you don't see bad corrosion, is the real peril.
art.
RDMG
Dave R
Northern Virginia
(138 posts)
04/07/2016 08:29PM
Posted by: RDMG
Date: November 17, 2018 12:59PM
Art.
I’m guessing I know the answer, but what do you think of this head— can it be saved?
All the corrosion seems to be near the gasket surfaces— deeper in the coolant passages it looks pretty smooth.
Dave
Date: November 20, 2018 11:35AM
"Looks" like galvanic reaction. Water or old-style coolant formula. Steel head gasket, alum. head and heavy amp flow,(ground at front of block, starter at back). You might learn more on hidden thicknesses with sonic tester. When clean, these heads weld-up great. For hi-perf., I would weld a "bridge" in center of dog bone. When heads are pristine clean in coolant areas, you can seal with, "egg keep", (sodium carbonate) ?
Good Luck, art.
